1969 GTO heater core - Pontiac GTO Forum
post #1 of 9 (permalink) Old 02-01-2012, 07:06 PM Thread Starter
Does anyone have a link or detailed pictures of how to rebuild the heater core? I have a bunch of foam seals from this kit but not sure where everything goes and I haven't been able to find any directions on how to rebuild it.
Thanks,
Chris
shelbee350 is offline
post #2 of 9 (permalink) Old 02-01-2012, 07:41 PM
FlambeauHO's Avatar
Quoted: 8 Post(s)
Everything is pretty self explanatory once the heater box is removed. You have a seal for the engine side of the firewall for the motor box. Small rectangular seals for the doors inside the box that direct the air (I used contact adhesive for these) a larger hollow rectangular one for the heater core itself once you scrape out the old strip caulk. Another for the motor itself (round one) and one for the dash side of the firewall to the heater box. That's all I can think of at the moment ... post pics of the ones you are having trouble with.
FlambeauHO is offline
post #3 of 9 (permalink) Old 02-02-2012, 08:48 AM
The seals are for resealing the heater box, but you don't rebuild the heater core, you just replace it with a new one.
post #4 of 9 (permalink) Old 02-02-2012, 10:12 AM
ppurfield001's Avatar
. I purchased a replacement heater core for my 1967 GTO from Ames. It's a bitch to get to it -- you had to remove the right front quarter panel to get to it in my ride. Good luck.
ppurfield001 is offline
post #5 of 9 (permalink) Old 02-02-2012, 06:34 PM Thread Starter
I meant the heater box in general. Would like to see how the whole heater box comes apart. I've rebuilt a 1965 mustang heater box and there are step by step instructions on the web as to where each foam piece goes. I can take pictures of what we have when I am at the location on Saturday. There was a bunch of what looked like caulking on the doors inside the heater box and not sure if that is correct or was a poor job of sealing it up to fix it. It was like a clear caulk of some type. any input or pictures would be great....Thanks....
post #6 of 9 (permalink) Old 02-02-2012, 07:56 PM
FlambeauHO's Avatar
Quoted: 8 Post(s)
Don't think there should be any clear sealant in there. Just strip caulk in black. Like I said you'll figure it out easily once you have it in your hands.
post #7 of 9 (permalink) Old 02-05-2012, 10:11 AM Thread Starter
Here are some pics of what we are working with. As you can see there is some stuff around that door and where the heater core itself sits...Is this correct or should there be foam there?
post #8 of 9 (permalink) Old 02-05-2012, 11:27 AM
That almost looks like someone tried to seal that door shut.
post #9 of 9 (permalink) Old 02-05-2012, 07:48 PM
Kinda odd looking isn't it? If'n it wuz me, I'd probably make a seal around that edge by gluing on a narrow closed cell foam strip and call it good. Once it's all together it's going to be completely invisible anyway, so I'd opt for something that works well over something that was "correct".
BearGFR is online now
heater core Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 11 12-14-2010 08:51 PM
heater core question denf221 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 04-30-2010 01:05 PM
'67 heater core Crikker 1964-1974 Tempest, Lemans & GTO General Discussion 16 11-29-2009 07:59 PM
Heater core replacement 1969 gto silky58 1964-1974 Tempest, Lemans & GTO General Discussion 3 07-30-2009 04:29 PM
69 Heater Core ramairthree 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 03-03-2009 06:42 PM
