1969 Judge Restoration Begins - Pontiac GTO Forum
post #1 of 20 (permalink) Old 05-20-2011, 12:37 PM Thread Starter
Hi Folks...this poor car's been waiting since 1986 to be redone, and now it's time. I know you're supposed to do the sheet metal replacement and then separate the frame and body, but they're already separated and I need to evaluate the frame first. Here come the pix !
Name:	SAUGATUCK,HOLLAND BULLDOZER,FAMILY ELMWOOD,DECK,GTO TRAILER 068.JPG
ID:	11180   Click image for larger version
ID:	11181   Click image for larger version
ID:	11182   Click image for larger version
ID:	11183   Click image for larger version
SPDMETL is offline
post #2 of 20 (permalink) Old 05-20-2011, 12:58 PM Thread Starter
More Pix
I don't know yet if the Captions worked...
ID:	11185   Click image for larger version
ID:	11186   Click image for larger version
ID:	11187   Click image for larger version
SPDMETL is offline
post #3 of 20 (permalink) Old 05-20-2011, 01:11 PM Thread Starter
A few more pictures
That's it for now. Next; how the hell do I attach the back ? Any and all suggestions and comments are welcome !
ID:	11189   Click image for larger version
ID:	11190   Click image for larger version
ID:	11191   Click image for larger version
SPDMETL is offline
post #4 of 20 (permalink) Old 05-20-2011, 01:39 PM
that body is in tough shape. you have a lot of work ahead. good luck.
freethinker is offline
post #5 of 20 (permalink) Old 05-20-2011, 06:41 PM
I used an engine hoist to raise the back up first and attached the roto, then I moved the hoist to the front, raised the car and rolled the frame out and then attached the roto to the front. I would suggest welding swivel wheels under the roto to move the car around in the shop.
05GTO is offline
post #6 of 20 (permalink) Old 05-21-2011, 10:42 AM Thread Starter
There isn't anywhere to bolt the rotisserie onto at the back of the body-see post #2, last pic. Also, it came with wheels, but their instructions say to remove them when you use it at the sides
SPDMETL is offline
post #7 of 20 (permalink) Old 05-21-2011, 11:26 AM
::whistle:: I see what you mean. That part of the trunk floor and the bracing in that area where the body mount usually goes is just... gone. Here's a suggestion: for now, keep it supported from the sides like you have. Get it up in the air enough to replace the trunk floor, the mounts, and braces first. Do that, then you'll have spots to mount the rotisserie.
post #8 of 20 (permalink) Old 05-22-2011, 07:46 PM
onetwomany's Avatar
Hey Speed. The way we went after mine was I had the body sitting on a snowmobile trailer where the whole trunk section hung off the back of the trailer. On my 65 85% of the weight was on the back side of the rocker panels.. We secured it to the trailer in front(pulling it down) while we did all the work on the rear section of the body. My bodyman was satisfied with the height which allowed him to work on the top or bottom side easily. Just my opinion. Hope this helps.
onetwomany is offline
post #9 of 20 (permalink) Old 05-22-2011, 07:53 PM
onetwomany's Avatar
As a side note. With the body off the frame the floor panels are structural members. If you plan to put the body on a roto you should tack weld braces in the door openings to prevent it from folding up on you. After your metal work is done you can cut your braces out and grind down any tack weld areas.
post #10 of 20 (permalink) Old 05-23-2011, 09:36 AM Thread Starter
Thanks for the answers, Gentlemen. The trailer idea is a good one, and I will be bracing with tubing. I feel obligated to come up with some really screwy-but-safe way to do this.
Now, you've all seen what I need to patch; steer me toward/away from sources for the sheetmetal.
Thanks ! Rolf
SPDMETL is offline
New member trying to get head around finishing Judge restoration ... michaelC 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 12 02-18-2011 08:21 PM
Build Sheet 1969 Judge Mentor 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 03-19-2010 09:11 AM
1969 GTO Judge Questions hockeyguy21 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 16 08-13-2009 05:38 PM
1969 GTO Judge Question dillon14 1964-1974 Tempest, Lemans & GTO General Discussion 6 04-06-2009 04:12 PM
1969 Judge in Competition Reno'sGoat 1964-1974 Tempest, Lemans & GTO General Discussion 2 12-17-2004 01:37 PM
