1972 Rust Bucket - Pontiac GTO Forum
 1Likes
  • 1 Post By 05GTO
post #1 of 5 (permalink) Old 04-06-2019, 06:54 PM Thread Starter
1972 Rust Bucket
I bought a 1972 LeMans Sport that’s turned out to be a rust bucket. I’m not super concerned yet as I’m not wanting a show quality car, nor am I in a hurry. The body was having to come off it anyways and I was already planning on replacing most of the body panels.
My question concerns rust in the areas you can’t see. For example: I’ve been cutting out the trunk floor to replace it, and the trunk/body support is full of rust even where it disappears out of sight under the part of the trunk you don’t replace.
What’s the best way to get it out, and is there a way to treat the inside so it doesn’t come back? I was considering drilling holes periodically along the channel to stick the nozzle of my pressure washer in and hopefully blast it all out. Curious as to people’s thoughts on that idea, and that also leaves how to treat it and keep it from coming back. I am already going to POR15 the frame and everything I can as it’s apart and cleaned, but can’t do that to little areas that can’t be seen.
Last question. Any other areas that I may overlook, even with the body off, where rust might be hidden and need treated?
Steel-W0LF is offline
post #2 of 5 (permalink) Old 04-07-2019, 09:20 AM
Quoted: 11 Post(s)
There is a product called OSPHO that I've used that can be brushed on or sprayed, it kills the rust and then can be painted with Por-15,
deanhickey likes this.
05GTO is offline
post #3 of 5 (permalink) Old 04-07-2019, 08:20 PM Thread Starter
I’ll check that out. Thanks.
Wonder if it’s thin enough to spray inside the body supports to treat the hidden areas.
post #4 of 5 (permalink) Old 04-08-2019, 05:02 PM
Quoted: 13 Post(s)
I canít speak for the longevity of this, but there is an Eastwood product I used that is designed for this purpose.
https://www.eastwood.com/eastwood-in...953f1d52c74d28
Colorado67GTO is offline
post #5 of 5 (permalink) Old 04-08-2019, 09:00 PM
1968gto421's Avatar
Quoted: 72 Post(s)
Originally Posted by Steel-W0LF View Post
Iíll check that out. Thanks.
Wonder if itís thin enough to spray inside the body supports to treat the hidden areas.
From their web site, it sounds like it is thin enough.
"OSPHO is water-thin, can cover a larger area than paint "
1968gto421 is offline
1972 gto front bucket seats Goatman1972 1964-1974 Tempest, Lemans & GTO General Discussion 4 12-02-2015 02:25 PM
zero rust vs rust encapsulator tspring 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 09-11-2011 07:07 PM
Small rust in trunk of a 66 Lemans-Big Concern?? darkalley 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 3 03-19-2005 12:32 AM
