4 speed console question - Pontiac GTO Forum
post #1 of 8 (permalink) Old 02-11-2015, 06:59 PM Thread Starter
Hello, I will be converting my 66 GTO to a 4 speed in the very early spring. I will be using a factory 4 speed console. Does anyone know if I need to use the metal trans hump adapter like the non consiole 4 speed cars have. I have never see a 4 speed console car with the console removed so I am unsure of what style it is. Any insight you may have is greatly appreciated. Thanks!
Lennox is offline
post #2 of 8 (permalink) Old 02-12-2015, 12:18 PM
Quoted: 117 Post(s)
Yes. It's called a shifter porch or sometimes a 'doghouse'. All the floorshift manual cars use it. As a bonus, it only fits in one place on the floor perfectly, so if you are doing a changeover like you are, you know right where to cut the hole. Simply place the doghouse in position, outline it, and cut the floorpan about 3/4" or so inside of the outline.
post #3 of 8 (permalink) Old 02-17-2015, 12:44 AM Thread Starter
Thank You. I guess I will need a GTO one as the one I have is from a 66 Chevelle. Seems like the GTO one is different.
Lennox is offline
post #4 of 8 (permalink) Old 02-18-2015, 02:55 PM
DSMTiger's Avatar
From my '66 restoration. Correct '66 4 speed console and the opening I cut in the new floor pan to accommodate the shifter. The cut was patterned after the original factory cut. One thing I did observe was that there was nothing precise or pretty about the cut that was made on the assembly line during original production.
ID:	52433   Click image for larger version
1966 TriPower, 4 spd, PHS documented.
DSMTiger is offline
post #5 of 8 (permalink) Old 02-18-2015, 11:56 PM
The main difference in the shifter porches used on manual shift '64-74 Pontiac A body's is the shape of the hole stamped out of the top. Early ones used a round hole, then Fisher body started installing shifter porches with a large oval shaped hole. 68-72 Chevelles received another style, as well as did Buick GS's. On A-bodys of this era, the shifter porches were screwed down into the floor pan and the opening below them was rough cut. On 2nd Gen Fbodys, their shifter porches were welded in then wiped around the steel edges with seam sealer.
post #6 of 8 (permalink) Old 03-21-2015, 06:49 PM
U should be fine
FMFC motorsports is offline
post #7 of 8 (permalink) Old 08-12-2018, 09:16 PM
shift porch
66 gto what porch am i suppose to use for a a console. ames says the squared one is supposed to be for a non consoles and the one with round hole is for console had someone tell me the opposite does anyone know for sure
rustytinman is offline
post #8 of 8 (permalink) Old 08-13-2018, 05:45 AM
GTOJUNIOR's Avatar
Quoted: 66 Post(s)
The non-console cars used the rectangular (Square) shifter boot and retaining ring.
Name:	66 NO CONSOLE FLOOR SHIFTER.jpg
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
Center Console for 67' 4 speed? smac8876 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 10 08-24-2013 05:02 PM
4 Speed Console ButchsGTO 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 5 10-07-2012 02:24 PM
64 to 65 4 speed console differences Al T 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 14 06-10-2010 03:39 PM
Is this a correct Shifter for a console 4 Speed xconcepts 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 7 08-13-2009 09:19 AM
