'64 Tempest - floor brace ends - Pontiac GTO Forum
post #1 of 11 (permalink) Old 01-11-2011, 03:46 PM Thread Starter
I just purchased the front floor brace ends for my '64 Tempest from PY. The ones for the brace directly under the front floor and the next one back. It appears that the cross-section at the inner ends does not match the existing braces. Also, the section where the body to frame bolts pass are not the same shape as the originals. Has anyone successfully used these braces before? Looks like a lot of modifications will be required.
Phil
64phil is offline
post #2 of 11 (permalink) Old 01-11-2011, 06:36 PM
66tempestGT's Avatar
welcome to the world of reproduction parts!
Shane Doss
66 tempest
64 el camino
02 mullis dragster
66tempestGT is offline
post #3 of 11 (permalink) Old 01-12-2011, 07:06 AM
67 Basket Case Restorer
Too Many Projects's Avatar
Is the brace possibly made to fit in or over the existing, or is it intended to directly replace the factory end ? I couple clear pics might help see what you're up against. I eventually need those for my 66 too and am curious as to their design.
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
post #4 of 11 (permalink) Old 01-12-2011, 07:56 PM
OrbitOrange's Avatar
aint it a bitch
OrbitOrange is offline
post #5 of 11 (permalink) Old 01-12-2011, 09:35 PM
Thor7352's Avatar
aint it a bitch
Yep, at least the repro parts give you something to start with...
Thor7352 is offline
post #6 of 11 (permalink) Old 01-13-2011, 03:59 PM Thread Starter
The braces are made to weld to the cut-off end of the old braces. Here are a couple of photos comparing original to new. The depth of the cross-section is deeper on the new ones (one side only) and the kick-up at the outer ends is significantly different. If I had it to do over again I would buy the full length braces. Then you only have to worry about welding them to the rockers.
Phil
[IMG][/IMG]
[IMG][/IMG]
64phil is offline
post #7 of 11 (permalink) Old 01-13-2011, 06:38 PM
Wow, not good. Have you called the supplier to see if you can return them for a full brace ? Might be worth the $12 to save time and hassle.
Maybe they grabbed the wrong part for the side that is so different...
Mitch
1962 Impala SS
1938 Chev coupe
post #8 of 11 (permalink) Old 01-14-2011, 10:32 AM
yep looks like they sent you the wrong one. i just put a set of those on a 55 ford sedan. 5 on each side and all 5 were different.
Shane Doss
66 tempest
64 el camino
02 mullis dragster
post #9 of 11 (permalink) Old 01-14-2011, 12:53 PM Thread Starter
I'm afraid that it's way more than $12.00 from Canada! All four have the same issues. The part numbers agree with their catalogue so they are just very poor reproductions. I am going to cut & weld them to fit up .
Phil
64phil is offline
post #10 of 11 (permalink) Old 01-14-2011, 04:30 PM Thread Starter
I finally figured out what is going on with these floor braces. I have two sets of the mid-floor braces and no front floor braces. The catalogue said to buy mid for front but there is no way. I have found another supplier that has the correct front braces. So, I will place my extra set of mid-floor braces on eBay and be done with it.
Phil
64phil is offline
65 Trunk floor /gas tank brace. injn37 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 3 03-15-2009 12:13 PM
Fiberglass Front Ends... TreySmith 1964-1974 Tempest, Lemans & GTO General Discussion 5 01-06-2009 07:36 AM
1964 Tempest Floor Rust 64phil 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 02-22-2008 11:33 AM
04-05 rear ends PEARL JAM 2004-2006 GTO General Discussion 3 04-09-2007 05:15 AM
Durability of rear ends chad1140 Racing and Kill Forum 2 04-09-2005 02:49 PM
