65 Back up lamp housing question - Pontiac GTO Forum
post #1 of 3 (permalink) Old 09-13-2012, 01:48 PM Thread Starter
Hey guys,
I have a question about the back up lamps on my restored (in progress) 65. The car originally had no reverse lights. I needed a new rear bumper anyway and purchased a repop with the backup lamp cut outs and a set of new lamp housings. I then realized that I needed the retainer brackets so I bought some as well. So I go to install them and realize that after tightening the brackets all the way, the housing is still loose. I then looked at my restoration guide and found originally a gasket was used between the bumper and lamp housing. I looked in some of my parts catalogs and no one seems to sell the gasket. Do I need this gasket? Is it thick enough to take up the slack? Who sells it? Do I have the incorrect retainer brackets? Is the repop bumper THAT much thinner than the OEM?
I could weld a few little tabs on the retainer brackets to extend them a little but if there's an easier fix I'd rather go that route.
Thanks for any info
Ken
gtotto is offline
post #2 of 3 (permalink) Old 09-13-2012, 03:56 PM
rickm's Avatar
Quoted: 5 Post(s)
i was able to reuse my original mounting gaskets, im sure you could make a set out of a sheet of gasket material if you had to. i recall that due to the contour of the bumper, they mount in bumper only one way. rickm.
rickm is offline
post #3 of 3 (permalink) Old 09-14-2012, 01:44 PM Thread Starter
OK thanks
gtotto is offline
Rear deck brake lamp housing SPICERED2006 Interior Discussions 0 07-09-2011 11:39 AM
Got her put back together and a question Coloradoman25 1964-1974 Tempest, Lemans & GTO General Discussion 8 04-17-2010 08:58 AM
65 GTO back bumper question. Chris Holabaugh 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 7 03-01-2010 11:09 PM
back seat question 66tri-power Interior Discussions 1 09-30-2007 02:07 AM
Flowmaster Cat-back Question Church Intake and Exhaust Discussions 2 08-10-2007 05:23 PM
