65 AT bracket for a tri power - Pontiac GTO Forum
post #1 of 3 (permalink) Old 07-26-2011, 11:17 AM Thread Starter
SIXT5GTO's Avatar
I have started looking for a bracket that holds the trans kick down switch for the 65 GTO tri power.
I have seen one picture that seems shows the switch mounted to the throtle cable bracket, is this correct,
Does anyone carry the parts i need
SIXT5GTO is offline
post #2 of 3 (permalink) Old 07-27-2011, 05:52 PM
66tempestGT's Avatar
what transmission? my 2 speed has the switch on the pedal inside the car. not a tri power but i think turbo 400 had the same thing too.
Shane Doss
66 tempest
64 el camino
02 mullis dragster
66tempestGT is offline
post #3 of 3 (permalink) Old 07-27-2011, 10:10 PM Thread Starter
SIXT5GTO's Avatar
66 was the change and the switch eletronic trans down shift switch was relocated to the peddle.
The first two years had the switch by the carb.
I just have not seen one for the tri power.
all I can figure is it mounted to the throttle cable bracket or there was a mounting bracket on the last carb.
SIXT5GTO is offline
'65 Tri-Power TheGreatBuzz 1964-1974 Tempest, Lemans & GTO General Discussion 4 12-01-2009 03:53 PM
Power Steer Bracket Help zzomby 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 10-04-2009 05:43 PM
Which tri-power intake was best? 65GTO421HO 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 06-24-2009 08:53 PM
Tri-Power GTO JUDGE 1964-1974 Tempest, Lemans & GTO General Discussion 5 03-01-2009 04:04 PM
