65 Gto body mount repair - Pontiac GTO Forum
post #1 of 15 (permalink) Old 09-23-2011, 11:46 PM Thread Starter
zzomby's Avatar
I'm replacing body mounts on my 65', I broke 7 bolts unfortunately. I'm now in the process of trying to repair them. Where can I get replacement cage nut housings, or do you guys just build your own. Is there a thread with some tips on this kind of repair? Thanks.
zzomby is offline
post #2 of 15 (permalink) Old 09-24-2011, 01:08 PM
Zom, there is acompany called GROUND UP they sell resto parts for Chevy products.....the catalog (I don't have ) showe the cage and the square nut for chevelle. look them up on line. Eric
Eric Animal is offline
post #3 of 15 (permalink) Old 09-24-2011, 10:58 PM Thread Starter
zzomby's Avatar
I found them at Ames. Thanks, Eric. Now I just have to practice my welding some more.
zzomby is offline
post #4 of 15 (permalink) Old 09-25-2011, 09:54 AM
Me too I haven't welded in years...I tried my new mig welder on an old door skin.....I am real good at vaporizing metal! E
ID:	12382   Click image for larger version
post #5 of 15 (permalink) Old 10-04-2011, 11:19 AM
peahrens's Avatar
Similarly, I want to get this done on my '66. I have the basic bushings/bolts/washer set and a few of the square nuts. If any of the receivers need repair, how many nuts and how many cages should I get? Is the Ames S387DC cage & nut item what I need? When I started this in '92 and backed off, one bolt just turned. Is this usually because the cage is broken and the nut just turns with the bolt? Does the new cage get welded on? Are the spots accessible (e.g., under the seat) to repair?
peahrens is offline
post #6 of 15 (permalink) Old 01-30-2012, 05:55 PM Thread Starter
zzomby's Avatar
Autobody Specialties Inc Only $6.00 Here fore the cage nuts plus a lot more parts than Ames.
zzomby is offline
post #7 of 15 (permalink) Old 01-30-2012, 07:28 PM
jetstang's Avatar
I apreciate the link Eric. Got my 66 back, stripped to bare metal, and a body bushing set on the shelf. Heard alot of hate on the subject, scared to even try to loosen the body mounts. Anybody have good pics, and access points if the cage breaks.
Burning rubber since 1982!!
jetstang is offline
post #8 of 15 (permalink) Old 01-31-2012, 05:39 PM
FlambeauHO's Avatar
Quoted: 8 Post(s)
About to do mine too... not looking forward to it but will post any wisdom gained..
FlambeauHO is online now
post #9 of 15 (permalink) Old 01-31-2012, 07:54 PM
Here are the only pics I have that might help....I can take some more next week. I can't right now as I just had surgery (again) and if I bend down, my head will fall off..... hope these help, but I don't think they will. Eric
ID:	13702   Click image for larger version
ID:	13703   Click image for larger version
ID:	13704   Click image for larger version
post #10 of 15 (permalink) Old 01-31-2012, 08:58 PM
Here's a link about removing rusty body mount bolts.
Might help.
"Basics of Basics" Rusted bolt in caged nut removal.
Russ
russosborne is offline
Body mount questions TK69tempest 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 02-28-2011 08:15 PM
Body Mount Repairs HANK67 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 05-21-2010 07:30 AM
Body Mount Bolts mmag36 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 12-01-2009 09:34 AM
67 GTO rear body mount repair fastgenious 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 1 10-22-2006 08:01 PM
