65 GTO A/C install - Pontiac GTO Forum
post #1 of 3 (permalink) Old 05-07-2014, 06:34 AM Thread Starter
65 GTO A/C install
wanting to use the factory center vent, and the side vents with a Classic Auto Air kit. Want the inside of the car to look like factory air. Anybody have any input into what obstacles I might run into? Help is appreciated
cparman is offline
post #2 of 3 (permalink) Old 05-09-2014, 02:39 PM
MWR
I did a Vintage Air install in my 65 and also wanted a factory look. I ended up skipping the center vent since the VA kit only has 4 outlets (and the factory setup has 5). I cut the holes and used repop side dash vents and mounted the Vintage Air crotch vents, which were close enough to the factory look for me. Cutting the holes for the side vents wasn't fun but it's OK if you take your time. I had a parts car that I used to make a template to locate the side vents.
MWR is offline
post #3 of 3 (permalink) Old 05-09-2014, 04:09 PM
I used a Classic Air system in my 69 and set it up to use the factory vents and controls. It's not easy, but it's possible. I sacrificed the lap vents and didn't install them at all, winding up with the two side vents and the center vent. Most of the work was involved with adapting their system to run with the factory controls, but I got it done - including all 4 fan blower speeds (the Classic system only came with 3 speeds) and "splitting" the on/off control from the fan speed control.
69 GTO Endura Install DanC 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 13 06-24-2014 07:48 PM
gto 4 speed install mikey9743 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 11-26-2012 05:45 PM
Did anyone Install aftermarket A/C into a '68 GTO? GasTiresOil 1964-1974 Tempest, Lemans & GTO General Discussion 15 11-19-2009 08:20 AM
2004-06 GTO Magnacharger Packages - $6289 Shipped w/ Free Install or Install Credit Mike Norris Engine Discussions 6 03-08-2007 07:11 PM
