65 GTO with a little bit of rust. - Pontiac GTO Forum
post #1 of 319 (permalink) Old 02-18-2010, 06:56 PM Thread Starter
Thumpin455's Avatar
Now I am not looking to detract from Mitch's work, it just happens that we have similar projects and some comments about his work inspiring others motivated me to post this one here as well. Why not show that if you apply yourself you can do more than you ever thought possible.
I am doing this for my father in law Dave, he helped me out when the USAF broke me and put me out. Gave me a place to live, fed me, and helped me get back on my feet. Well Dave had a 65 GTO convertible that he sold in 68 when his first daughter was on the way. He mentioned it and said it was the only car he would ever want back, so I picked a rolling shell hardtop up in South Carolina with a little bit of rust. Its a real GTO PHS verified to have been a 4 speed 4 barrel in Montero red.
It has been here since 2006 as the project I would get to when I could. Then back in November Dave ended up in the hospital with heart problems and I decided it would be a good time to get started on his car. Dave turns 65 on May 5th this year so that is the deadline, another cool part of this whole thing is the VIN ends with 00065, so that is like providence having that many 65s all at the same time.
Here it is right after it got up here to Michigan. Doesnt look all that bad from here.
Could be worse, at least it has seats in it right?
And no engine or trans.
Thumpin455 is offline
post #2 of 319 (permalink) Old 02-18-2010, 06:59 PM Thread Starter
Thumpin455's Avatar
The trunk reminded me of a speech years ago, 1000 points of light.
A bit of rust on the seal channel.
Holy smokes where was the window resting, in the back seat?
Takin it apart.
post #3 of 319 (permalink) Old 02-18-2010, 07:05 PM Thread Starter
Thumpin455's Avatar
Chipped bondo off the quarter panel with a putty knife, didnt have to sand a bit to get to this point. Someone really screwed things up back in the 70s or 80s. Patched a quarter from a Tempest on it with a stick welder. Got the body off the frame, that was fun.
Built a rotisserie out of 3x2 box and hung the body on it.The casters cost as much as the steel did!
Sandblasted the frame in a freezing rain storm, remind me not to do that again.
post #4 of 319 (permalink) Old 02-18-2010, 07:07 PM Thread Starter
Thumpin455's Avatar
Found more rust. The dash was held in by the wiring harness and the little plastic thing around the column.
Got to sanding and blasting on the body to find all the areas that need attention.
Painted the frame! Yes going the other way!
post #5 of 319 (permalink) Old 02-18-2010, 07:11 PM Thread Starter
Thumpin455's Avatar
Waited a month for the floor pans, there was a screw up and they didnt ship them for three weeks. Got to cutting and pasting when they got here.
Hacked the trunk out with a sawzall and replaced the braces under it that hold the tank in place. Got some Eastwoods encapsulator brushed on the spots that will be hidden when its all done.
post #6 of 319 (permalink) Old 02-18-2010, 07:13 PM Thread Starter
Thumpin455's Avatar
Well they are in there, not finished welded yet but close enough so the car has some structural integrity again. Been blasting and sanding on it since I shot these weeks ago, its getting there but my blaster died today so I need to order up a new larger one. Less time filling more time knocking crust and oxidation off!
I'll take some pics of it soon to update it.
post #7 of 319 (permalink) Old 02-18-2010, 07:26 PM
Nice!! Looks like your doing good work!
post #8 of 319 (permalink) Old 02-18-2010, 07:28 PM
67 Basket Case Restorer
Too Many Projects's Avatar
What is the build date of that car ? with a VIN of 00065, it looks to be one of the very first ones built...
You have a very ambitious completion date...good luck. I'll have to wish Dave a happy b-day ....we share the same day....but I'm not quite 65....
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
post #9 of 319 (permalink) Old 02-18-2010, 10:36 PM Thread Starter
Thumpin455's Avatar
Its not the first run through the sequence, so its a late build. Hey wanna see who gets done first? Did you get a frame yet?
post #10 of 319 (permalink) Old 02-18-2010, 10:41 PM
I'll be lucky if mine see's the road May 5th of 2011...
I do have a frame. Went to Oklahoma last March for it.
Mitch
1962 Impala SS
1938 Chev coupe
A bit depressed mmitch777 2004-2006 GTO General Discussion 19 07-07-2007 09:30 AM
1969 GTO Rust Issue Chucks69 1964-1974 Tempest, Lemans & GTO General Discussion 1 12-16-2006 09:10 AM
Chomping at the bit spylab 2004-2006 GTO General Discussion 0 08-16-2005 04:47 PM
