65 GTO Tri-Power Automatic Kick Down Cable - Pontiac GTO Forum
post #1 of 3 (permalink) Old 04-17-2018, 06:52 PM Thread Starter
I just got this GTO and found the kickdown cable just hanging in the motor bay. Does anyone have the documentation to install a kickdown and what bracket do i need for the cable. I"m not sure why i don't have the right bracket or if the car uses a different way of kickdown, but it's not working. Thank you
engine - 389
automatic trans
Convertible
Tri-power
allantagg is offline
post #2 of 3 (permalink) Old 04-17-2018, 08:09 PM
Reads like someone has replaced the original transmission, most likely the 2spd auto Super Turbine 300, with a later Turbo 350 3spd auto. Turbo 350's had a kick down cable. Super Turbine 300's did not. This question has come up before, I would contact Mike Wasson, the Pontiac Tripower guru and see what he offers for kick down cable attachment to an early 2G rochester center carb.
http://www.pontiactripower.com/
post #3 of 3 (permalink) Old 04-20-2018, 03:34 PM Thread Starter
Thank you, will reach out to Mike and research to see what transmission was installed.
Running a built 421, 65 GTO, Tri-power, considering a 66 Tri-power setup avman 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 4 07-28-2018 10:46 AM
Kick down cable connect to tri power Topless66 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 3 11-10-2017 12:42 PM
66 Tri Power, TV cable setup ? JOE CAPP 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 0 11-30-2016 08:26 PM
'65 Tri Power, throttle cable too long? CP-Mike 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 07-10-2014 10:43 PM
64 Tri power Automatic Trans, kickdown switch marks64 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 07-20-2009 06:29 PM
