65 leak into passanger compartent - Pontiac GTO Forum
post #1 of 2 (permalink) Old 05-24-2011, 08:28 PM Thread Starter
crustysack's Avatar
well after a horrific rainstorm last night I found the 65 had accumulated a bit of water in the passenger compartment after some looking i have found that the windshield cowl drains directly into the area behind the kick panel and then down the rocker panel and out a hole before the rear wheel. Well i have cut up the kick panel metal to allow the passage of heater hoses, ac hoses and a multitude of wiring, seems the hole I cut allows water to freely run into the passenger compartment . solution was to build a carbon dam to funnel water from the cowl to a specific area, draining directly down. then filling all the holes I cut with silicone around the hoses/wires hopefully this will work. I will test tomorrow with the hose- wish me luck
crustysack is offline
post #2 of 2 (permalink) Old 05-24-2011, 08:47 PM
66tempestGT's Avatar
you park that car in the rain?! sounds like you have it under control. good luck.
Shane Doss
66 tempest
64 el camino
02 mullis dragster
66tempestGT is offline
gas leak Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 8 05-08-2011 11:37 AM
leak 04blueskys Drive train, suspension, alignment and brakes. 1 03-20-2011 02:33 PM
Passanger Brake Problem HELP! Bluestreak018 Exterior Discussions 2 08-21-2009 11:41 PM
Pesky leak 66GTO7.5L 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 14 04-28-2009 03:59 PM
Water Leak in '06 Ladybug Interior Discussions 3 12-12-2008 02:17 PM
