65 progress - Pontiac GTO Forum
post #1 of 5 (permalink) Old 11-08-2010, 05:52 AM Thread Starter
crustysack's Avatar
65 progress
been a while since posted some pics- work is super busy(thankfully)- got the rear seats cut down and fit, got the radiator plumbed and the air intake done- after 4 tries cutting and welding to fit around everything, got the amps installed,and started to build the rear center console that will house the sub.I have now resolved for a spring launch date, thought it would have been this year but due to work I wasnt able to work on the car in august or sept. Probably a good thing keeping me from rushing some stuff
ID:	9223   Click image for larger version
ID:	9224   Click image for larger version
ID:	9225   Click image for larger version
ID:	9226   Click image for larger version
crustysack is offline
post #2 of 5 (permalink) Old 11-08-2010, 08:22 AM
Crusty....very cool ....the sub looks like Iron Man's arc reactor!!!!
Eric Animal is offline
post #3 of 5 (permalink) Old 11-08-2010, 10:32 AM
66tempestGT's Avatar
looking good. that radiator hose is yelling at me!
Shane Doss
66 tempest
64 el camino
02 mullis dragster
66tempestGT is offline
post #4 of 5 (permalink) Old 11-29-2013, 08:25 PM
What kind of seats did you use in your car? What are they out of?
Keith
Keith37f20 is offline
post #5 of 5 (permalink) Old 11-30-2013, 08:38 PM Thread Starter
crustysack's Avatar
seats are out of an 06 gto, I had to modify them slightly
the 06 is MUCH narrower so I cut the middle section out and pushed them outboard, I also had the upper bolster section removed because it was much to high. I do run the headrest and you can easily see out the rear window
ID:	30226   Click image for larger version
progress on my tempest 66tempestGT 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 166 05-10-2014 10:02 AM
65 progress crustysack 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 13 08-12-2010 09:43 AM
67 Resto progress Eric Animal 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 11 05-11-2010 07:49 PM
65 progress crustysack 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 10-24-2009 09:02 PM
More progress ??!!?? Too Many Projects 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 03-09-2009 06:57 PM
