'66 Fender splash seals - Pontiac GTO Forum
post #1 of 9 (permalink) Old 04-07-2012, 12:37 PM Thread Starter
MaL
MaL's Avatar
Send a message via AIM to MaL
Anyone have a picture of which direction these attach to the inner fender wells?
MaL is offline
post #2 of 9 (permalink) Old 04-09-2012, 06:54 PM
FlambeauHO's Avatar
Quoted: 8 Post(s)
Bump
Figure it out yet? I have em too
FlambeauHO is offline
post #3 of 9 (permalink) Old 04-10-2012, 08:17 PM
jetstang's Avatar
I'm sure they are stapled on, just don't know where you get a stapler that can handle that. I guess drill the holes, then insert the staples and bend.
Burning rubber since 1982!!
jetstang is offline
post #4 of 9 (permalink) Old 04-11-2012, 08:00 AM
Yoiu will need either a VERY heavy duty stapler, OR, a small drill bit to make the holes......the small piece goes like this (see pic)...The large piece is kinda self explanatory once the inner fender is on the car. Those are correct for 66, I have a 67, they are just rectangles on the 67 (not as nice)...Eric
Eric Animal is offline
post #5 of 9 (permalink) Old 04-13-2012, 11:13 AM Thread Starter
MaL
MaL's Avatar
Thanks for the small piece picture! That cleared that one up nicely.
I drilled 1/16th holes and the staples fit snugly.
And it looks like the large one comes from underneath the lip (from the tire side) and into the bay folding out over the A-arm. Right?
MaL is offline
post #6 of 9 (permalink) Old 04-13-2012, 06:21 PM
Correct...it looks like it will be easy to see which way it lays over the A-arm, as it has an irregular shape. E
post #7 of 9 (permalink) Old 04-19-2012, 08:21 AM
I purchased a set of these for my 65 GTO. I am having trouble as well figuring out how they lay against the Inner Fender Wells. They do not mach the originals, as the originals covered the open area at the A-Arm and then narrowed out and went towards the radiator between the flange of the Inner Fender Well and the Frame. (Originals were longer and covered more area) The new ones I purchased only cover the open area at the A-Arm. Are the ones you guys purchased shorter than original as well? If not I would like to know where yours were purchased from. Thanks
timmyg is offline
post #8 of 9 (permalink) Old 04-19-2012, 03:43 PM
This is how mine are installed on the 66;
05GTO is offline
post #9 of 9 (permalink) Old 04-19-2012, 08:04 PM
Quoted: 23 Post(s)
i need to do mine, was thinking of doing them in clear poly after all that work i did making my A-arms and suspension look pretty....
Instg8ter is offline
66 Lemans Inner fender splash shield question buvens 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 2 09-22-2011 12:44 PM
Installing inner fender seals on a 68 GTO dglty 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 3 04-07-2010 07:49 PM
Splash/mud guards RicanGoat Exterior Discussions 8 10-03-2009 06:27 PM
Mitsu Eclipse GT V6- Splash One Groucho Racing and Kill Forum 40 08-03-2005 08:13 PM
