66 gto ac vacuum line diagram needed - Pontiac GTO Forum
 4Likes
post #1 of 33 (permalink) Old 11-01-2010, 10:07 PM Thread Starter
help i need a diagram of the vacuum lines for the air con , i didnot take the car appart so i dont know where any of the hoses go any help would be great thanks
azaapcom is offline
post #2 of 33 (permalink) Old 11-04-2010, 10:54 PM Thread Starter
please can anybody help me with this , i need to put the vacuum hoses back so i can fit the dash , any help would be great thanks
azaapcom is offline
post #3 of 33 (permalink) Old 11-05-2010, 10:23 AM
From the service manual for 1967, but I am almost sure 66 is the same.The small "round wheel" in the lower left corner is the dash control. The vacuum ports are numbered. Eric
ID:	9198   Click image for larger version
ID:	9199   Click image for larger version
ID:	9200   Click image for larger version
Eric Animal is offline
post #4 of 33 (permalink) Old 11-05-2010, 09:12 PM Thread Starter
thank you mr animal that is very helpfull , please check out my web site www.azaap.com if you need any rust free arizona parts also some pics of the gto i am doing $25 hour shop rates for restorations , my wife will up date the web pictures on sunday so you can see all my pontiacs mostly ta,s
azaapcom is offline
post #5 of 33 (permalink) Old 11-06-2010, 06:47 AM
MY pleasure. I could use a rust free 67 GTO shell......Cool pygmy goats and nice puppies ! Eric heres's a couple of my "critters"
post #6 of 33 (permalink) Old 10-31-2017, 11:39 PM
CPL
Quoted: 14 Post(s)
I have a 65 this looks the same,except for were the lines connect at the junction to go out to the engine.is that a canister or a junction into one line to engine?
thanks
CPL is offline
post #7 of 33 (permalink) Old 11-01-2017, 04:29 AM
GTOJUNIOR's Avatar
Quoted: 66 Post(s)
If your referring to round/circle portion of the schematic, if you look close you will note there are numbers.
That circular image represents the Vacuum Valve/Control head.
Similar to this;
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #8 of 33 (permalink) Old 11-01-2017, 09:53 AM
CPL
Quoted: 14 Post(s)
My vacuum lines go threw the fire wall I don’t have that pice.at some point who ever had my car first cut the vacuum lines coming out into the engine compartment.the scamatic looks the same until you get to that vacuum valve.
CPL is offline
post #9 of 33 (permalink) Old 01-03-2018, 08:02 AM
Quoted: 14 Post(s)
This is good information but does anyone have a schematic of the vacuum lines as they route into and through the engine bay?
Thank you,
Andrew
Andrew69 is offline
post #10 of 33 (permalink) Old 01-08-2018, 03:00 PM
Quoted: 14 Post(s)
To be more specific I need to know how to route the 1/8" vacuum lines that come through the firewall in the upper part of the heater box. Anybody have a similar car that you can send me some photos?
Attached is a photo I found on line to clarify which lines.
Thank you,
Andrew
Name:	GTO 67 Vacuum Lines.JPG
Andrew69 is offline
68 GTO Wiring Diagram iCdeez 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 02-01-2018 08:19 AM
1974 GTO Carb Vacuum Diagram dastoria 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 04-13-2010 07:17 PM
64 GTO vacuum line diagram greengrad1977 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 03-01-2010 07:58 PM
74 GTO Vacuum Diagram ra34inm 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 12-14-2009 08:41 PM
