66 lemans headliner bow set - Pontiac GTO Forum
post #1 of 5 (permalink) Old 04-13-2012, 01:59 PM Thread Starter
how many headliner bows are supposed to be in the 66 models? when i bought my car it had 4 bows but my headliner has holes for i think 6.
woolsey10 is offline
post #2 of 5 (permalink) Old 04-14-2012, 01:16 PM
rickm's Avatar
Quoted: 5 Post(s)
'64-'67 have 5 bows im pretty sure.
rickm is offline
post #3 of 5 (permalink) Old 04-14-2012, 07:44 PM
67 tempest I only had 4 bows, 2 before the dome light 2 behind. I used a 1/8 straight rod in the center along the support. I started in the center and worked forward then worked to the rear, then snugged up from side to side, used a hair dryer ( thanks honey ) to work it a little as well. If you have four bows you should be good.......
fasterfiero is offline
post #4 of 5 (permalink) Old 04-14-2012, 07:53 PM
And if your headliner has 6 listings ( seams, pockets, sleeves, whatever you call them) you must have got yours from the same dummy on Ebay as I got mine from, 66-67 and two styles of sail panels. Get plenty of spray adhesive for the edges.
post #5 of 5 (permalink) Old 04-15-2012, 02:28 PM Thread Starter
i got my headliner from ames performance. i recounted and it has 5 sleeves. i guess i'll see if i can order the missing bow separately. thanks everyone and thanks fasterfiero for the installation info.
Headliner nightmare OrbitOrange 1964-1974 Tempest, Lemans & GTO General Discussion 11 06-27-2017 09:02 AM
replacing headliner in 66 lemans woolsey10 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 1 10-18-2011 03:40 PM
Headliner installed crustysack 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 03-06-2011 05:51 PM
headliner glue?? crustysack 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 03-08-2010 03:58 PM
Headliner blondie67 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 06-16-2008 02:10 PM
