66 seat back problems - Pontiac GTO Forum
post #1 of 5 (permalink) Old 11-15-2015, 01:06 PM Thread Starter
almost finish with frame off restoration, having problems stripping paint off seat backs. aircraft stripper won't work. i am scared i will damage the woodgrain finish if i sandblast or warp it. if anyone has any advise i need it!
sc66gto is offline
post #2 of 5 (permalink) Old 11-15-2015, 08:50 PM
Help me remember, are the seat backs textured?
05GTO is offline
post #3 of 5 (permalink) Old 11-16-2015, 09:52 AM
Quoted: 100 Post(s)
Textured stamped metal. Like a pebble grain. I would try paint remover or perhaps brake fluid. I've never stripped any of my '66 or '67 seat backs....they never needed it. That paint holds up as well as the original upholstery in these cars.....unreal.
post #4 of 5 (permalink) Old 11-16-2015, 10:18 AM
Glass bead cabinet, do not use sand.
Have restored quite a few lower apron panels for '66 and '67 A body buckets that had a few small pinholes to even small gapped areas missing from rust. when completed, the repaired areas were not noticeable.
post #5 of 5 (permalink) Old 11-16-2015, 06:29 PM
Thanks,
I would use steel wool to scuff the surface and paint with a 60% gloss paint. If your using the brush on gel aircraft stripper, try the aerosol spray, it seems to be stronger.
05GTO is offline
Seat Back Seat Panel and Plastic Clips DPSlaz Interior Discussions 7 12-29-2013 12:10 AM
Seriously, will a car seat fit in the back seat? kllrvet 2004-2006 GTO General Discussion 3 09-23-2005 10:18 PM
