66 Shifter linkage - Pontiac GTO Forum
post #1 of 3 (permalink) Old 04-24-2011, 09:18 AM Thread Starter
xconcepts's Avatar
66 Shifter linkage
So I've got a hurst quick shift t-handle in my GTO at the moment. I'm replacing it with the original hurst shifter and console here in a couple months. My question though is the linkage the same for both shifters?
Also, I see a couple shifters on ebay with a mounting plate as well. Will I need that for the original?
xconcepts is offline
post #2 of 3 (permalink) Old 04-24-2011, 11:45 AM
Quoted: 98 Post(s)
You'll need the mounting plate, but it's probably already on there for the "quick shifter". The linkage may or may not work. A lot of it is interchangable but not visually "correct". Congrats on sticking a stock round Hurst shifter back in!! They work GREAT!
post #3 of 3 (permalink) Old 04-24-2011, 01:47 PM Thread Starter
xconcepts's Avatar
So I'd need to pull the shifter to find out if it would fit then OEM shifter.
64 GTO automatic shift linkage 23plumpt 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 1 05-03-2015 09:41 AM
Question about 64 GTO powerglide shifter linkage Bryan H 1964-1974 Tempest, Lemans & GTO General Discussion 3 05-09-2013 10:24 AM
carb choke linkage Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 2 03-02-2011 11:20 PM
carb linkage Topkat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 02-19-2011 06:09 PM
1965 clutch linkage bracket Pontiac Tempest Cstm 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 03-23-2010 07:46 PM
