67 Floor Pan color - Pontiac GTO Forum
post #1 of 3 (permalink) Old 03-18-2012, 08:12 PM Thread Starter
67 Floor Pan color
I am cleaning and painting the frame and floor pans of my 67. I am trying to determine the correct color of the floor pans? As you can see from the picture where I have cleaned they are light gray and black. Are they sprayed from the factory with a undercoating? If so what color? If you look at the picture you can see the before and after cleaning, the pans around the transmission have not been cleaned. Amazing what 45 years of dirt will do.
OldToys is offline
post #2 of 3 (permalink) Old 03-19-2012, 07:50 AM
FlambeauHO's Avatar
Quoted: 8 Post(s)
Think they should be 60% gloss black. What are you using to clean the undercarriage? I'm having a heck of a time with mine, any tips?
FlambeauHO is offline
post #3 of 3 (permalink) Old 03-19-2012, 10:26 AM
On my undercarriage, after sandblasting, I first used an epoxy sealer-primer, then sprayed with 3-M's paintable undercoating (PN 08882) and finished off with the 60% gloss black,
If you have a well ventilated area and protective clothing use an aerosol aircraft stripper. Klean Strip in the aerosol form is better than their brush on remover. I would also suggest using a respirator.
05GTO is online now
floor pan 67chivo 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 0 10-15-2011 03:42 PM
wet floor dieseltweaker Interior Discussions 5 04-17-2010 07:29 AM
Floor is out jonsyp 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 08-11-2008 05:00 PM
Does clutch need to go to the floor? ponyeater Drive train, suspension, alignment and brakes. 3 07-09-2006 07:31 PM
What color floor mats should I get? Scissors 2004-2006 GTO General Discussion 5 01-02-2005 01:35 PM
