67 GTO Backup light question - Pontiac GTO Forum
post #1 of 3 (permalink) Old 12-15-2013, 10:47 AM Thread Starter
I have a 4 speed car and installed a new dash harness. Somebody routed the backup light wire down through shifter hole. The harness seems like it should go through the firewall with the wiper motor plug. Can anyone verify this.
chance1992 is offline
post #2 of 3 (permalink) Old 12-15-2013, 11:48 AM
Quoted: 118 Post(s)
On my 4 speed '65, the wiring does not go through the firewall at all. It goes from the switch on the trans to the engine side of the firewall, where it connects to the harness by the junction blocks. It is held to the side cover of the trans by two small sheet metal brackets to keep it clear of the shift linkage. Both wires are fused together, like a lamp cord. None of the backup switch wiring is inside the cabin of the car.
post #3 of 3 (permalink) Old 12-16-2013, 01:41 AM Thread Starter
Thanks for the reply. The wiper wire come through a grommet right next to the junction block.The signal from the switch on the Trans has to go to the lights in the rear by the harness inside to the rear of the car you have helped a lot thanks for the help.
1969 GTO Backup Lights not working CgyGTO 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 10-15-2013 08:48 PM
1965 GTO Backup Light Gasket Chips 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 5 03-11-2013 09:12 AM
1965 GTO Backup Lights Gasket Chips 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 03-04-2013 08:59 PM
70 GTO forward light harness question sweet70gto 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 09-13-2012 01:50 AM
1966 GTO - Routing Backup Light Switch Extension Harness jasonjuul 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 05-13-2010 01:40 PM
