67 GTO find - Pontiac GTO Forum
post #1 of 21 (permalink) Old 12-27-2015, 09:00 PM Thread Starter
67 GTO find
Hello,
Im new to this board. I recently found a 67 GTO. The car is a 4 speed car hardtop. Thinking about buying it. The car has sat in a shed for the last 20 years. apparently the previous had to much to drink and hit a light pole in the parking lot. The drivers door has a dent and the rocker is pushed in. The Drivers quarter has some indirect damage as well. I looked the car over and it is complete. however upon looking i discovered that the passenger quarter has been replaced as well but they cut off the quarter from another car. There is a weld seam on the sail panel that is visable from the interior of the car. There also is a weld seam under the filler panel behind the rear window. and a seam on the tail panel. After reading all this is the car still worth putting back together. The owner is asking $3500. The body is otherwise damage free and rust free, The frame is straight with no issues as well also clean title. Like to read your comments and advise. If I buy this I would like to find some quarters to fix these issues or a parts car that has decent quarters and a good passenger side quarter and inner braces on the sail panel.
01freeman is offline
post #2 of 21 (permalink) Old 12-27-2015, 09:12 PM Thread Starter
options for rear quarters on a 67
I am curious what is available for a 67 GTO quarter panels. I have a car that needs both quarters. the left side is damaged and the right side was replaced and was done poorly. What do you recommend or suggest.
post #3 of 21 (permalink) Old 12-28-2015, 04:28 AM
As a recent 67 purchaser myself, I can tell you that any part you're looking for is available. Whether it be used off of sites like frankspontiacparts.com or new reproduction parts. Just depends on your budget. Pretty easy to spend thousands of dollars, especially on a car that has been sitting for 20 years.
Winged is offline
post #4 of 21 (permalink) Old 12-28-2015, 11:33 AM
Full repro 1/4s hit the Westcoast a few months ago. Ck with Ames, or for that matter any nearby Camaro/Chevelle supplier that orders in shipping containers of Dynacorn repop sheetmetal.
post #5 of 21 (permalink) Old 12-28-2015, 09:44 PM Thread Starter
More pictures
ID:	69354   Click image for larger version
ID:	69362   Click image for larger version
ID:	69370   Click image for larger version
post #6 of 21 (permalink) Old 12-28-2015, 09:48 PM Thread Starter
Pictures of the passenger side quarter replacement that was done
ID:	69386   Click image for larger version
ID:	69394   Click image for larger version
ID:	69402   Click image for larger version
ID:	69410   Click image for larger version
post #7 of 21 (permalink) Old 12-28-2015, 10:00 PM Thread Starter
Here are some pictures of the car. And the pictures of the damage and the quarter panel job that was done on the right side
ID:	69426   Click image for larger version
ID:	69434   Click image for larger version
ID:	69442   Click image for larger version
ID:	69450   Click image for larger version
post #8 of 21 (permalink) Old 12-28-2015, 10:04 PM
Does the car come with the original numbers matching engine?
05GTO is online now
post #9 of 21 (permalink) Old 12-28-2015, 10:11 PM Thread Starter
The owner said the engine is not original. The original one was replaced after it was blown in the 70's
post #10 of 21 (permalink) Old 12-28-2015, 10:19 PM
Please don't take this the wrong way, but you will spend 2 to 3 times what the car is worth restoring it. If the engine was the original engine you could narrow that down to 1.5 - 2 times the value.
JMHO
05GTO is online now
Anyway to find out if your old GTO is still around? NAVHAZ 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 0 05-17-2013 02:56 PM
Anyone know where to find a Gto? brodg 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 13 06-29-2012 09:25 AM
Help me find my GTO! Stingraye 2004-2006 GTO General Discussion 11 12-28-2005 05:08 AM
Where to find GTO's? buckwheat_88 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 4 11-15-2004 02:14 PM
