67 GTO frame off resto help - Page 2 - Pontiac GTO Forum
 4Likes
post #11 of 105 (permalink) Old 10-06-2009, 09:19 PM
That is one smoooooooth chassis!!!!!! Looks sweet Eric
Eric Animal is offline
post #12 of 105 (permalink) Old 10-06-2009, 10:00 PM
67 Basket Case Restorer
Too Many Projects's Avatar
WOW, really nice, wish mine was that far along.....
Jeff, you can get bolts for the upper ball joints with the heads that replicate rivets. The nuts are mostly hidden underneath. I have them on my winter wish list from Ames....
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
post #13 of 105 (permalink) Old 10-06-2009, 11:26 PM
Quoted: 11 Post(s)
drburns,
Nice work, she appears to be a factory A/C car.
Keep the pictures coming.
05GTO is offline
post #14 of 105 (permalink) Old 10-07-2009, 09:59 AM Thread Starter
drburns's Avatar
Quoted: 4 Post(s)
You are correct about the factory A/C. It's actually a very nicely optioned car. It's got power steering, power disc brakes, AM/FM, rear speaker, power antenna, and TH400. I kinda wish it was a 4 speed car though. Thanks for the compliments guys.
2004 GTO M6
Torrid Red/red interior
Mods: AES 390 with TVS 2300, too much to list...
721rwhp, 822 rwtq
1967 GTO 400 H.O. w/ turbo 400
Cameo Ivory w/ champagne gold interior: ongoing frame off resto
drburns is offline
post #15 of 105 (permalink) Old 11-27-2009, 11:38 PM Thread Starter
drburns's Avatar
Quoted: 4 Post(s)
Update: well I finally got some of the front end issues straightened out and have reassembled and painted the diff. I'll try to get some pics up this weekend. Issues I've been dealing with (for those interested) are finding good, unboxed reard lower control arms, having to replace my axles, finding a correct centerlink, and rebuilding the rear brakes. I've decided to go a little crazy with the resto, so aftermarket stuff is pretty much out. Here's some of my advice/findings:
1. While I'm using a lot of Inline Tube parts, they're rear brake kits have some issues. They're backing plates don't have the adjuster holes punched in the backing plate or the drum, so there's no way to adjust the rear brakes. So I restored my original backing plates and used the new internals. Nice thing is, now the Delco stamp is there and they look more original/correct. Otherwise, I really like the Inline Tube parts, especially they're bolt kits and lines.
2. I've gone through multiple sets of tie rod adjuster sleeves b/c the outer tie rod was threading crooked only to find the outer tie rod was not cut with the correct threads. Beware of cheap repo tie rods, especially the inner ones. I ended up restoring mine.
3. Front end steering components were originally black, as I noticed while sanding them. You were all right; thanks guys.
4. Aftermarket sway bars look completely different, and none are the correct size. If you can restore yours, do it. Idler arms have the same problem.
5. To my surprise, I had to replace my axles. The bearings had worn into the axles causing excessive play. Another nice $400 surprise I didn't expect. Aftermarket axles have a very different appearing hub/end, but i really didn't have much of a choice.
6. Finally, some one reproduces the original 2-piece front disc brake rotors! Cheap too: $209/pair. Of course this happens 1 month after I spent $200 on a pair of aftermarket replacements, but nonetheless, they are available. I'll post pics soon. (Not important unless you want to go 100% original).
Bottom line is, with a little TLC, original parts can clean up well, and keep your car original. Again, I'm going for a completely originally resto, including frame/parts decals, etc., probably over-restoring. I'd like to document as much of the resto as possible, so if anyone has any info, feel free to post it, especially frame detailing and inspection markings. I haven't found any good 67 frame off resto guides online, so I'll try to do it here. Suggestions and criticism welcome.
2004 GTO M6
721rwhp, 822 rwtq
drburns is offline
post #16 of 105 (permalink) Old 11-27-2009, 11:56 PM Thread Starter
drburns's Avatar
Quoted: 4 Post(s)
Here are some crappy pics from today using my phone. I'll get better pics tomorrow, hopefully. Another aftermarket issue; the upper control arms have a different contour where it mates to the bushing on the diff, and has a reinforcement plate welded to the bolt holes. Not really visible when totally assembled, but different from original. The trans just needed a little cleaning and detailing and new seals. I sanded and cleaned the pan, then cleared it. The rest of the housing was painted with alumablast.:
ID:	6069   Click image for larger version
ID:	6070   Click image for larger version
ID:	6071   Click image for larger version
ID:	6072   Click image for larger version
2004 GTO M6
721rwhp, 822 rwtq
drburns is offline
post #17 of 105 (permalink) Old 11-27-2009, 11:57 PM Thread Starter
drburns's Avatar
Quoted: 4 Post(s)
The rear axle housing is only primed in these pics. I painted it with GM resto black (60* gloss). I painted the backing plates with Eastwood phosphate black. Here you can see the hub/end of the axle. It's flat/flush instead of that cupped and cast look of the originals. Again, no one should be able to see that.
ID:	6074   Click image for larger version
ID:	6075   Click image for larger version
2004 GTO M6
721rwhp, 822 rwtq
drburns is offline
post #18 of 105 (permalink) Old 11-28-2009, 01:24 PM
Quoted: 11 Post(s)
Feel free to use the Photo Gallery, any pictures you upload can be accessed with the "My Photos:" link under your avatar.
05GTO is offline
post #19 of 105 (permalink) Old 11-29-2009, 12:56 AM Thread Starter
drburns's Avatar
Quoted: 4 Post(s)
Nice! Added a few more.
ID:	6090   Click image for larger version
ID:	6091   Click image for larger version
ID:	6092   Click image for larger version
ID:	6093   Click image for larger version
2004 GTO M6
721rwhp, 822 rwtq
drburns is offline
post #20 of 105 (permalink) Old 11-29-2009, 12:28 PM
Everything is lookin awesome!
69 GTO Remove body from frame cy***uy 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 5 09-09-2009 09:52 AM
TSB Information for 06 GTO Red Bearded Goat 2004-2006 GTO General Discussion 4 06-02-2007 10:00 AM
Pontiac GTO again flexes its muscles 05GTO In the News 5 05-06-2005 11:25 AM
Pontiac GTO Drifter - Car & Driver (Jul 04) m1das In the News 13 09-29-2004 09:11 PM
