67 GTO fuel line to carb hook up with A/C - Pontiac GTO Forum
post #1 of 1 (permalink) Old 02-14-2012, 06:29 PM Thread Starter
Trying to correctly hook up my fuel lines including vent return line on a 67 GTO with a/c and Californiia A.I.R. equipment. Vent line in frame blocked off, as is vent return outlet on fuel pump and small outlet on gas filter when purchased.
Have purchased vendor pre bent lines (3) double outlet gas filter and fuel pump with vent return outlet.
Can't figure out how to run the lines to the carb etc. Can anyone help?
wipeoutwilly is offline
1967 GTO Rochester QJet Fuel Line from Pump to Carb size 3rd1967gto 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 11-27-2016 06:49 AM
Need fuel line dr68 1964-1974 Tempest, Lemans & GTO General Discussion 0 08-08-2011 12:04 PM
where does turbo 400 vac line connect to carb? skapegoat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 09-20-2010 07:17 PM
66 GTO fuel line DRD57 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 12-03-2009 07:34 PM
New Fuel Line? coolhandgoat Service, Maintenance and Technical Discussion 4 04-09-2007 01:22 PM
