67 gto stainless trim along sill how to remove - Pontiac GTO Forum
post #1 of 4 (permalink) Old 04-14-2014, 06:36 AM Thread Starter
fiesta62's Avatar
hi, i have to remove the stainless trim that runs between front wheel to rear wheel along the bottom sill on my 67 gto, is there any trick or tips to remove it , i need to paint the front guard so its got to be removed, thanks
fiesta62 is offline
post #2 of 4 (permalink) Old 04-17-2014, 06:08 AM
I'm going by a cobwebbed memory here, but there should be screws on the bottom. Remove those and gently pull toward and lift at the same time. Should slide right off but be gentle so it doesn't jump up hard and scratch the finish.
666bbl is offline
post #3 of 4 (permalink) Old 04-19-2014, 06:45 AM
SANDU002's Avatar
Before you remove the trim, run a 3" wide of painters tape on the body to protect the paint in case the trim pops up as stated above.
67 Post Coupe,
69 RA III Judge
06 BOM, M6, 18's
SANDU002 is offline
post #4 of 4 (permalink) Old 04-22-2014, 08:18 PM Thread Starter
fiesta62's Avatar
yeah thats a good idea , i use painters tape a lot, i had rust around tailights got it all fixed but now when i wash car i run the wide tape over lenses no water gets in, takes 5 minutes but worth it in the long run, thanks
fiesta62 is offline
Stainless or aluminum trim bobby326 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 12-21-2012 09:05 PM
How do I remove the door vent trim & instrument cluster trim? batmans Interior Discussions 13 05-11-2011 06:11 PM
How To Remove GTO Steering Wheel Trim Covers???? 1LS1 2004-2006 GTO General Discussion 1 01-05-2011 11:21 PM
Door sill trim takethegoat Interior Discussions 2 08-06-2009 05:05 PM
Stainless trim on pedals... rick3452 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 08-30-2008 08:17 AM
