67 Lemans tail light swap - Pontiac GTO Forum
post #1 of 9 (permalink) Old 06-23-2011, 11:25 PM Thread Starter
gotyorgoat's Avatar
Just picked up a 67 Lemans and can not stand the tail lights. Looks like a granny car. Does anyone have experience with converting them to the GTO style? Do I need to replace the whole panel or is there a simpler way?
For the Lemans enthusiest, I do not mean to offend. Just personal preference.
ID:	11517   Click image for larger version
gotyorgoat is offline
post #2 of 9 (permalink) Old 06-24-2011, 12:07 AM
Quoted: 23 Post(s)
of all the treatments the LeMans was the most boring....at least the 66' had the crescents and the sweet 4' fluted "Pontiac" the best treatment of all even GTO IMHO...although i may be a bit prejudiced.... Yes to do the GTO or any other treatment you have to do the whole panel from quarter to quarter, need to weld brace in before removing and weld the panel in so you would also need to paint the rear end....its a pretty major undertaking and the lights and louvers are not cheap. your probably talking 800 in materials, ? on labor at least as much, plus paint blending.
1966 Tempest pictures by instg8ter - Photobucket
Brian
Instg8ter is offline
post #3 of 9 (permalink) Old 06-24-2011, 07:17 AM
You COULD cut the metal where the tail lights are and graft in metal from a 67 GTO light panel....then you will need a GTO rear bumper for the reverse lights. You will need to alter the rear light harness to acommidate the new lights. Like Brian said, changing the entire panel is the proper method, but you will end up doing a lot more body work and paint.....Eric
Eric Animal is offline
post #4 of 9 (permalink) Old 06-24-2011, 07:33 AM
Quoted: 23 Post(s)
Hey Eric, you don't have a spare trunk deck trim bar laying around from your parts car do you? I never noticed the 67's quarter trim was different. 67' GTO bumper will have rectangular reverse lights GotYourGoat, the 66' will have round and the LeMans they're in the light housing. if you can get a GTO light housing you may be able to do as Eric said and just fabricate the openings or weld in on the panel and not the seams, still not a weekend project.
post #5 of 9 (permalink) Old 06-24-2011, 07:47 AM
Brian, the 66 trunk has a different shape than a 67...therefore the 67 trim WON"T fit the 66......
post #6 of 9 (permalink) Old 06-24-2011, 10:57 AM
Quoted: 23 Post(s)
Ahhhh, yep ends in a different place on the curl....learn something new every day. ames has them listed (Inquire), you know what that means.....LOL. have to order me some front wheel well trims, have two brand new backs i picked up cheap and the one front i have is well worn, maybe i will inquire then and bend over.....Thanks E
post #7 of 9 (permalink) Old 06-24-2011, 12:42 PM Thread Starter
gotyorgoat's Avatar
Thanks for the help. Sounds like with the right parts and some cut and patch, I could make it work without cutting out the whole panel. I do like the look of the 66 lemans. That is a beautiful car.
post #8 of 9 (permalink) Old 06-24-2011, 12:47 PM Thread Starter
gotyorgoat's Avatar
Instg8ter - What color is your Lemans? I think that I just found my new favorite. Please give me as much paint info as possible and maybe another pic. Thanks.
post #9 of 9 (permalink) Old 06-24-2011, 02:53 PM
Quoted: 23 Post(s)
Thanks GotYor, if you click the link at the bottom of my post there are 900 pics of the whole build start to finish, the color is GM Bahama Blue Metallic, picked it because it is dead nuts match to Barrier blue (original color) with a very fine metal flake in it. Mine is tempest Custom but i loved that Lemans tailpanel piece so much i had to have it...hard to find.
Brian
Tail Light Housing GTOcop 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 4 01-17-2018 08:04 PM
HELP!!! Please 67 tail light wiring 67wayz 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 11 04-04-2011 09:12 PM
tail light issues.... evs9684 Service, Maintenance and Technical Discussion 2 01-10-2008 10:44 AM
tail light tint 6.0goat Exterior Discussions 17 11-10-2007 09:17 PM
Tail-Light Swap BitterGenius 2004-2006 GTO General Discussion 11 07-31-2006 05:52 PM
