67 Wheelhouse Steel Question - Pontiac GTO Forum
post #1 of 4 (permalink) Old 04-09-2015, 05:33 PM Thread Starter
Quoted: 13 Post(s)
I purchased an AMD inner left wheelhouse piece, but I am still missing a piece. I don't know what it might be called and am wondering if it is made separately or only sold with some wheelhouse pieces.
In the first picture below, you will see it is the roughly triangle shaped piece that is at the bottom of the wheel well and connects the fender to the inner wheelhouse and the trunk drop piece. The second picture is of the AMD piece I purchased. The third picture is off of Ebay and if you look closely, this wheelhouse looks like it has that piece welded to it. The last picture is also from Ebay and it is both the inner and outer wheelhouse together, but clearly shows the piece I am talking about at the bottom.
Does anyone know what this piece is called and if it can be purchased separately or do I just need to find a different brand wheelhouse with that piece attached. I will need it for both the left and right sides.
Any help is always appreciated.
ID:	54970   Click image for larger version
ID:	54978   Click image for larger version
ID:	54994   Click image for larger version
Colorado67GTO is online now
post #2 of 4 (permalink) Old 04-09-2015, 08:49 PM
I had to fabricate mine, couldn't find them anywhere either
SOCMedic is offline
post #3 of 4 (permalink) Old 04-09-2015, 10:27 PM
jmt455's Avatar
Same for my 68: I had to fabricate the replacement piece.
1968 Pontiac GTO
2008 Pontiac G8 base
jmt455 is offline
post #4 of 4 (permalink) Old 04-14-2015, 10:40 PM
bobby326's Avatar
I ordered a driver and pass rear wheel well from performance years and it came as all one piece.
bobby326 is offline
Outer wheelhouse replacement - 70 GTO Orion88 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 02-03-2015 01:20 PM
14" steel wheel question rickm 1964-1974 Tempest, Lemans & GTO Wheels & Tires 2 09-22-2014 11:35 PM
65 GTO frame off restoration, wheelhouse question bw5500 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 0 08-31-2013 08:04 PM
Picture needed, wheelhouse/trunk tie-in Fred007 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 5 11-02-2009 08:57 PM
widen steel wheels and offset question PontiacDave 1964-1974 Tempest, Lemans & GTO Wheels & Tires 0 07-19-2009 10:36 AM
