'68 Frame off Restoration - Page 2 - Pontiac GTO Forum
Juice564
 3Likes
post #11 of 56 (permalink) Old 01-23-2016, 02:33 PM
dan woodland's Avatar
Quoted: 34 Post(s)
Looks great Juice564!! Nice work! I'm glad to see another GTO headed toward being back on the road! Keep us updated.
dan woodland is offline
post #12 of 56 (permalink) Old 02-28-2016, 04:49 PM Thread Starter
Juice564's Avatar
Quoted: 5 Post(s)
Quick update, rear end of frame is now complete.
Juice564 is offline
post #13 of 56 (permalink) Old 02-28-2016, 06:33 PM
Quoted: 404 Post(s)
Looking good. I don't see any control arm braces. I would suggest adding them for insurance. Very easy to bolt up. I used the UMI braces as they have a slight bend to them that is supposed to better clear the floor - no hammering to fit. They are also adjustable for an easy line-up of the bolts, again, no hammering or fighting with them.
They come in red or black and have all the hardware to install -grade 8 bolts. Summit has them 4028-R & 4028-B. UMI sells them at the same price, but Summit offers free shipping over $100, so a little savings. UMI Performance Control Arm Reinforcement Brace Kits 4028-R - Free Shipping on Orders Over $99 at Summit Racing
There are other brands and even the factory style, which may be cheaper, but since you have it apart it'll be easy to install.
Name:	04  Supports.jpg
post #14 of 56 (permalink) Old 02-28-2016, 09:09 PM Thread Starter
Juice564's Avatar
Quoted: 5 Post(s)
I didn't even know those existed! I'll ad them to the list and go do some research on them. Thanks for the tip!
Juice564 is offline
post #15 of 56 (permalink) Old 03-03-2016, 12:40 PM
Juice 654,
Great job so far and yes my 68 had rot in the same spot as yours up on the top of the rear 1/4. As far as the braces, they were factory items for four speed cars, I would still add them to your project. Is that springmist green?
Anthony
Nightshade 68 HO is offline
post #16 of 56 (permalink) Old 03-04-2016, 02:12 PM
DT-Fan's Avatar
Quoted: 5 Post(s)
Nice work! How many hours did you put into it up to now? Looking forward for the next pics!
DT-Fan is offline
post #17 of 56 (permalink) Old 03-04-2016, 08:56 PM
You are doing a great job. Has all the rust my '68 Lemans has. What's up with the rear corner caps at the rear quarters rotting out? I gotta repair mine as well along with trunk floor and quarters and...............
Mine were gone too, but only on the side where it had rusted through around the back window. I've decided that what must have gone on, is that once it eats through the window channel and starts leaking into the trunk (which takes out the wheel house, lowest portion of the quarter panel, etc. as I'm sure you're well aware) some of the water must cling to the inner underside of the quarter and flow downhill all the way into those corner caps.
post #18 of 56 (permalink) Old 03-04-2016, 09:03 PM
Nice work your'e doing there, Juice. let me add my vote for control arm braces. UMI does make some very nice ones that follow the contour of the floor and are also adjustable for length. That's what I have on my car.
post #19 of 56 (permalink) Old 03-04-2016, 09:06 PM
Quoted: 404 Post(s)
Yep, I figure once you get water/moisture in the trunk it must rise and collect in those corners, especially on those hot days when the moisture is burned off & up. Surprised no one offers replacements yet as it does seem common enough.
My trunk got rotted out due to the bad trunk seal which had rotted away and let water pour in, along with the window channel rot.
post #20 of 56 (permalink) Old 03-05-2016, 08:46 AM Thread Starter
Juice564's Avatar
Quoted: 5 Post(s)
Originally Posted by Nightshade 68 HO View Post
Juice 654,
Anthony
Funny you should ask that, when I bought the car I thought that was the color and that is the name of the color on the PHS documentation i ordered. However I kept finding factory silver overspray everywhere. Come to discover later the car is currently sprayed in Limelight green. Springmist green is actually more of a silver and will be the color the car will be going back to.
Juice564 is offline
69 GTO frame restoration gubby 1964-1974 Tempest, Lemans & GTO Paint Shop Discussions 2 12-13-2016 06:36 PM
Boxed frame restoration Shadetree Racing 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 12-17-2015 05:32 PM
Frame-off restoration rmfowler 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 5 08-27-2012 09:10 PM
67 Frame on Undercarriage restoration OldToys 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 22 04-30-2012 01:02 PM
71 Lemans First Frame Off Restoration OrbitOrange 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 88 09-20-2011 02:06 PM
