68 GTO Convertible Hood Alignment - Pontiac GTO Forum
post #1 of 3 (permalink) Old 05-30-2016, 02:08 PM Thread Starter
Quoted: 4 Post(s)
Hello, Could anyone give me some tips in aligning the hood on our 68 GTO convertible? I simply loosened the two bolts on the spring assembly on one side a lifted on the hood. It's close, but I wanted to somehow fine adjust the alignment. The problem is you have to re-tighten the bolts, then close the hood to check the alignment. It's sort of hit and miss. Any suggestions would be appreciated. Thanks
mwatson1647 is offline
post #2 of 3 (permalink) Old 05-31-2016, 09:34 AM
Need more info, or pictures of what's not adjusted proper.
post #3 of 3 (permalink) Old 06-01-2016, 04:14 PM Thread Starter
Quoted: 4 Post(s)
Thanks for your response. I'm trying to align the hood to the fender up by the cowl. The driver's side of the hood is just slightly lower than the fender. It's OK on the passenger side. I just thought there might be some kind of screw adjustment or something that can be made without loosening the large bolts holding on the spring assembly to the inner fender and sort of blindly pulling the hood up, then getting it further out of alignment. Any help would be appreciated.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
chuckm166
68 convertible hood latch alignment Oldphart 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 3 02-26-2016 04:31 PM
Hood alignment 1969GTOkid 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 1 02-21-2012 08:12 AM
'66 convertible door alignment help Miami Ragtop 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 4 01-30-2012 06:13 PM
1964 Convertible Door Alignment Wedges? Al T 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 6 09-16-2010 10:26 AM
Need hood alignment help on a 65 oldtexasgoat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 12-14-2008 10:20 AM
