69 fan spacer bolt question - Pontiac GTO Forum
post #1 of 16 (permalink) Old 07-20-2019, 10:59 AM Thread Starter
Quoted: 17 Post(s)
I have the correct water pump, and pulley, the 2.5 inch spacer (535253) and correct balde ( 9791346) but the spacer bottoms out on the pump snout before its on far enough to seat the pulley against the pump snout? What am I missing here? It appears that the snout isn't going into the spacer far enough? Thanks
greenjudge69 is offline
post #2 of 16 (permalink) Old 07-20-2019, 02:05 PM
BLK69JUDGE's Avatar
Quoted: 74 Post(s)
Is that where my bubble gum went ??
is there a burr on the bore of the hole ?
how fa r out does the shaft protrude thru the fan mounting flange ??
pics of your water pump snout??
BLK69JUDGE is online now
post #3 of 16 (permalink) Old 07-20-2019, 05:20 PM Thread Starter
Quoted: 17 Post(s)
The bore of the spacer has what looks like a sleeve about 1/4 of an inch in from the end of the side that slides over the water pump snout that's preventing it from going on far enough to seat fully
post #4 of 16 (permalink) Old 07-20-2019, 07:28 PM
BLK69JUDGE's Avatar
Quoted: 74 Post(s)
never seen a sleeve in any of mine
post #5 of 16 (permalink) Old 07-20-2019, 08:20 PM Thread Starter
Quoted: 17 Post(s)
My mistake. I thought it was a sleeve but it looks like it was not bored deep enough to the correct I.D. it only needs to be about .080 deeper to fit properly
post #6 of 16 (permalink) Old 07-20-2019, 08:25 PM Thread Starter
Quoted: 17 Post(s)
Here is a picture of the water pump. It's a new version of the " short style" that Ames sells for the early 69 models.
post #7 of 16 (permalink) Old 07-21-2019, 12:34 AM
BLK69JUDGE's Avatar
Quoted: 74 Post(s)
wow
that shaft is stickin" WAY out there somethin doesnt look right
is that a new AMES repro ? I dont remember seeing one with that clean and sharp casting number
how does your pulley line up with the crank ?
wonderin if the shaft was positioned correctly on assembly ?
post #8 of 16 (permalink) Old 07-21-2019, 08:43 AM Thread Starter
Quoted: 17 Post(s)
That is an Ames repro.
post #9 of 16 (permalink) Old 07-21-2019, 08:44 AM Thread Starter
Quoted: 17 Post(s)
Pulley alignment is right on
post #10 of 16 (permalink) Old 07-21-2019, 08:36 PM
Quoted: 404 Post(s)
Originally Posted by BLK69JUDGE View Post
wow
x2, seems way to long on the stick-out. Shorten with a die grinder/cut-off wheel and polish up with a grinder. If you drill the spacer, you may oversize the hole or even offset drill it - unless you can chuck it all up on a drill press. You don't want any vibrations as the pin/hole should be tight.
