69 GTO with Body Bolts broken - Pontiac GTO Forum
post #1 of 3 (permalink) Old 05-08-2011, 11:12 PM Thread Starter
Years ago I separated the body and frame, leaving the thing spaced away on 2x4 stacks. 7 of the 10 body bolts broke off. What can I do to attatch the Rotisserie to the back of the car so I can roll it over so I can fix the broken bolts so I can properly bolt the car to the Rotisserie ?
SPDMETL is offline
post #2 of 3 (permalink) Old 05-08-2011, 11:40 PM
I think you're going to need to get the body up in the air and braced on something temporarily so you can go to work on it with lots of WD40, a drill, and a good EZ out (or two or three).
MagnumBS is offline
post #3 of 3 (permalink) Old 05-09-2011, 11:52 AM
You should probably replace the nuts IMO.
Body Mount Bolts mmag36 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 12-01-2009 09:34 AM
thunk in trunk lead to broken lug bolts? BlueBomber Drive train, suspension, alignment and brakes. 13 12-20-2006 01:57 PM
Broken GTO Driveshaft at Bradenton! Doc GTO Audio & Video Clips 10 01-28-2006 06:48 PM
My GTO got broken it! qonoximiento 2004-2006 GTO General Discussion 10 01-10-2005 09:58 AM
