69 gto body mounts - Pontiac GTO Forum
post #1 of 6 (permalink) Old 01-28-2014, 02:10 PM Thread Starter
69 gto body mounts
Can some one tell me how many body mounts hold the body to the frame on a 69 gto coupe. I thought there were 10 but I only see 8 that are bolted and 6 that are just the rubbers. Am I missing something ?
75tntrv is offline
post #2 of 6 (permalink) Old 01-29-2014, 09:35 AM
dan woodland's Avatar
Quoted: 34 Post(s)
Are you including the radiator core support mounts?
I have not investigated this for mine yet but sites like this say there are 14 plus the two radiator core support mounts - but apparently they included them in this kit which they didn't last time I looked.
1968-72 GTO Body Bushing Kit, Complete (OPGI) coupe, bushings w/hardware @ OPGI.com
dan woodland is offline
post #3 of 6 (permalink) Old 01-29-2014, 12:07 PM
The attached file has the applicable page, straight out of the factory service manual.
1969 GTO Hardtop used 7 mounts on each side of the frame. 4 on each side used bolts, 3 on each side were just the solid rubber biscuits.
(In the diagram, model 4237 denotes GTO hardtop, model 4267 denotes GTO convertible)
File Type: pdf 1969_Pontiac_Service_Manual_Section_2-3.pdf (47.5 KB, 285 views)
post #4 of 6 (permalink) Old 01-29-2014, 03:44 PM Thread Starter
Thanks bear. I thought there should have been another set bolts up in the spring perch. I have a extra set of mounts in my kit I will stick them up front where I can put a nut on it. Thanks again big help.
75tntrv is offline
post #5 of 6 (permalink) Old 05-31-2019, 08:35 AM
I am doing a resto on my 1969 Goat. Where is the best place to buy body mounts? I am using a frame from a 1971 Olds 442. My original frame was not usable. Thanks. Enjoy ur day.
gubby is offline
post #6 of 6 (permalink) Old 05-31-2019, 09:19 AM
curtis.smith68's Avatar
I'm really happy with the OPGI body mount kit. It has extra's i didn't use but it's not all inclusive for GTO's either. The GTO vs. Lemans has additional mounts that OPGI does not explicitly disclose when you are looking at their complete body kit and you will need to also order the supplemental body mount kit. Check out post numbers 28 and 30 of my thread on this exact topic. I have an image there also of the location of the mounts in the diagram they supply versus the original mounts I removed.
https://www.gtoforum.com/f83/68-gto-...82/index3.html
curtis.smith68 is offline
Body mounts 1966 Dozermatt 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 4 01-26-2014 04:35 AM
1965 Body Mounts Dunnburger 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 1 01-05-2014 03:36 PM
can body ,mounts be replaced without removing body off fiesta62 1964-1974 Tempest, Lemans & GTO General Discussion 10 12-26-2011 10:49 PM
1969 gto body mounts (help please) la_belle_fermier 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 02-27-2011 03:17 PM
body mounts dave74 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 02-07-2010 03:51 AM
