69 gto restoration - Pontiac GTO Forum
post #1 of 9 (permalink) Old 12-30-2014, 06:01 PM Thread Starter
69 gto restoration
Guys the pictures of my 69 goat resto more to come.
ID:	50337   Click image for larger version
ID:	50345   Click image for larger version
ID:	50353   Click image for larger version
ID:	50361   Click image for larger version
1969 gto is offline
post #2 of 9 (permalink) Old 12-30-2014, 08:18 PM
That sure looks familiar and brings back memories...
What are your plans for the car? Holler if we can help you.
post #3 of 9 (permalink) Old 12-30-2014, 09:03 PM Thread Starter
Lot of you guys have already, I finally figured how to reduce the picture size to be able to attach the pictures. I got her stripped down, front clip off, most of the interior just the dash left, gas tank bumper and tail lights, the usual. The body work will start soon, quarters patched, got other fenders that have been repaired, some patch work around the window wells, and some minor patches in the floor and trunk. The interior will be repaired/replaced and painted a different colour, combination of what ever it takes to get it done. I have not decided on a colour yet, drivetrain is either a rebuilt Pontiac 400 stroked out, or, if I dare admit it, a BBC because they are quite often available used at a fraction of what a Pontiac would cost. Complete suspension upgrade and fresh brake components. So it's going to be a long 4 or 5 years and not to mention expensive. She is generally very solid, frame, floors, doors and rockers, I think I lucked out.
ID:	50377   Click image for larger version
ID:	50385   Click image for larger version
ID:	50393   Click image for larger version
ID:	50401   Click image for larger version
1969 gto is offline
post #4 of 9 (permalink) Old 12-30-2014, 10:29 PM
Nice!
If you find yourself with a bad case of insomnia sometime, you can check out my project photos here:
My 1969 Pontiac GTO Restoration Project - Personalized photo album in html with PhotoOnWeb by VSO
post #5 of 9 (permalink) Old 12-31-2014, 06:01 PM Thread Starter
BearGFR couldn't wait for a case of insomnia so I looked through the pictures. Great documentation of the restoration, it gave me encouragement and helped with the drive for my project. You and Ben did a great job, hope mine comes out half has good. I need help figuring out how to take the roof rail weatherstrip, and any info on taking the door glass out. Should I just start a new topic thread?
1969 gto is offline
post #6 of 9 (permalink) Old 01-01-2015, 10:55 AM
To remove the roof rail weatherstrips, pull the rubber parts out of the chrome parts (they're glued in and will probably be a mess to get out if they're old and crusty). Underneath the rubber down the center of the chrome strips you'll find that the chrome is held to the body with a series of sheet metal screws. Remove the screws, and then CAREFULLY remove the chrome parts. There's a rubber seal between them and the body and there's probably also adhesive there, so you'll have to carefully coax them off so you don't damage them.
To get the door glasses out, remove the interior door panels and all the hardware/felt stripping around the window slot in the top of the door (you need some wiggle room there). Then you disconnect the window from the regulator mechanism (at the bottom edge of the window) and lift the windows out.
post #7 of 9 (permalink) Old 01-01-2015, 12:54 PM Thread Starter
Thanks bear, I will try it next weekend when I get a chance. I can't get the felt on the door out with the glass in , glass does not go far enough down to clear some of the screws that hold the felt on the door. Is it not possible to take the glass first then the felt after the glass? Also anything special to taking the glass from the regulator? Like where should the glass be positioned, up or lower or mid position,to make it easier, if there is such a thing as easier? I did not have that good of a look, what hold the glass to the regulator? Thanks again.
1969 gto is offline
post #8 of 9 (permalink) Old 01-01-2015, 01:37 PM
To be honest, I don't remember exactly. I just figured it out as I went along. I -think- there are some pins/clips involved that you have to remove in order to separate the class from the mechanism. If you can get your hands on a Fisher Body manual, the information will be in there.
post #9 of 9 (permalink) Old 01-01-2015, 03:53 PM Thread Starter
That's one of the books I will be buying soon, the fisher body manual and the gto restoration guide, but I some how think it will not match the experience, and the hands on knowledge of all the members, who gone through the trails and errors of an actual restoration such as yourself. But it can save some time in answering the simple procedures, so saving unnecessary questions directed to this forum's members. Thanks for your help Bear and everyone else who has helped in the past.
1969 gto is offline
68 GTO restoration dmjxgto Member Introductions 3 09-11-2014 12:19 PM
68 gto restoration MWRITE 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 2 07-15-2014 03:53 PM
69 GTO Restoration rmfowler 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 10 04-19-2013 06:34 PM
70' Gto Restoration - Need Help TreySmith 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 25 07-16-2009 11:34 AM
Restoration of 69 GTO TomGoat 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 03-20-2008 07:03 PM
