69 judge diff. Code help - Pontiac GTO Forum
post #1 of 3 (permalink) Old 12-07-2016, 09:22 PM Thread Starter
Quoted: 14 Post(s)
I need some help decoding my judges diff. The casting number on the center carrier is, 9795084, on the left axle tube is xk, which is a 390 gear and 4 pinion carrier. But left of that is the number 801, but the 1 is stamped upside down. Is that a date code? Is it 108 upside down??? Above the 9795084 is the number 57. Any help appreciated. Still has the original 390 gears in it which look good. Thank you
greenjudge69 is offline
post #2 of 3 (permalink) Old 12-08-2016, 05:40 AM
9795084 is the center housing casting number for a '69 nodular iron 8.2 A-body center housing. This particular center housing was used with following '69 Pontiac 8.2 A-body rears:
-3.55 Safe-T-Track,
-3.90 HD Safe-T-Track,
-4.33 HD Safe-T-Track
The small 57 cast above the 9795084 casting number is the Julian date (day of the year) the center housing was cast. 57th day is Feb 26th. XK denotes 3.90 HD STT. The 0118 1 stamping I'd love to see a picture of, need to look at '69 housings I have & see if any date stampings are upside down. On this particular rear, the date assembled, the 118th day would be in late April. 1 is shift 1. Your Judge was built in late May, in Arlington, that is good, fairly tight dated original rear... many original HD STT application rears were dated further out, ESP the 4.33's
post #3 of 3 (permalink) Old 12-08-2016, 06:29 AM Thread Starter
Quoted: 14 Post(s)
Thank you, here are some photos.
ID:	84066   Click image for larger version
ID:	84074   Click image for larger version
1969 GTO Judge Correct Distributor Casting Code gtfjudge 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 04-17-2014 01:22 PM
69 GTO Judge block date code Jwross 1964-1974 Tempest, Lemans & GTO General Discussion 8 02-05-2013 04:46 PM
04 diff/05 diff banshee 2004-2006 GTO General Discussion 8 08-23-2007 08:26 PM
Radio Code and Key Code Card Darrin 2004-2006 GTO General Discussion 3 01-06-2005 10:42 PM
