69 motor mounts - Pontiac GTO Forum
post #1 of 5 (permalink) Old 04-07-2016, 07:50 PM Thread Starter
dan woodland's Avatar
Quoted: 34 Post(s)
69 motor mounts
Hi all,
I'm pulling my Pontiac 400 power plant for a rebuild, my motor mounts are heavily cracked and requiring replacement.
Ames Performance has some for $18 each but I wonder if they are the model mounts I should use or not so I thought I'd ask the masses.
I ask because on a previous project the Anchor aftermarket mounts I bought make for a much "rougher" idle at stop lights than the OE mounts I replaced.
As always any help would be greatly appreciated. Dan
*67K miles... Under Construction* :)
dan woodland is online now
post #2 of 5 (permalink) Old 04-08-2016, 12:45 PM
Basically 4 choices...
-common parts store/ Internet retailer cheap rubber motor mounts. '64-72 Pontiac V8 A body (not to be used with '70-72 factory 455 A body frame stands). Anchor has been around a long time, one time made them in S Korea, maybe China, now... buy em, they go bad, install another pair, that's typical route...
-new old replacement stock (NORS) from the 70's, early 80's. have bought out quite a few parts stocks, both dealer parts stocks and partstore stocks from late '70's-mid 80's. One parststore stock came out of a Greenlight Auto shut down in '77, and then over a semiload went to a retiree aged Freight liquidator guy that ended up with had a monster stash of autoparts in his local building. Took me quite a while to ID the original motor mounts from that deal, there were nearly 4 bushel baskets of loose mounts and a bunch of crumbling small boxes. Many of the mounts sold at swappers and early Ebay. All motor mounts were in great shape and made in the USA. There are deals out there just have to hit swappers all the time and know what you are looking at.
-polyurethane mounts from Butler. $150 a pair plus ship, expect some noise transfer.
-have had friends buy the MityMounts. they are nothing but the cheap offshore mounts with a limiting bolt, for an extra $70... not that good a design, just a good money maker for the creators.
post #3 of 5 (permalink) Old 04-09-2016, 01:29 PM
rickm's Avatar
Quoted: 5 Post(s)
the regular motor mounts that ames sells that are made by either ancor/ doan, or republic will give you many years of service. by the time they need to be changed, you probably wont own the car anymore.
rickm is offline
post #4 of 5 (permalink) Old 04-09-2016, 03:31 PM
When I had my motor out of my '70 I replaced those mounts with ones from NAPA. That was in 2011. No issues. The ones replaced were well worn they appeared to be OEM and were nearly identical to the ones I got from NAPA which were cheaper than Ames at the time.
post #5 of 5 (permalink) Old 04-10-2016, 04:23 PM Thread Starter
Quoted: 34 Post(s)
Thanks gents, I appreciate the information/ideas!
Turns out I'm 10 minutes from an NPD warehouse this week so I'll try there as well.
Dan
Motor Mounts bsanchez 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 1 07-02-2015 01:55 PM
how to change the motor mounts Chris-Austria 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 6 03-09-2014 12:11 AM
motor mounts Topkat 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 14 01-31-2011 04:31 PM
Hi....motor Mounts/tx Mounts 67conv? 67conv400 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 12-23-2005 07:53 AM
