69 ram air lll carb - Pontiac GTO Forum
post #1 of 4 (permalink) Old 11-20-2016, 06:20 PM Thread Starter
Quoted: 17 Post(s)
69 ram air lll carb
Hi. What is the correct carb number for a 69 ram air lll 4 speed judge?? Thanks
greenjudge69 is offline
post #2 of 4 (permalink) Old 11-23-2016, 06:14 PM
I believe for the WS it's: 7028273
post #3 of 4 (permalink) Old 11-23-2016, 09:46 PM
-Early production '69 RAIII stick used the abbreviated part number style 28273 Ram Air Qjet. This style Qjet is date stamped on drivers side rear corner of the throttle body.
-Later production '69 RAIII used full part number 7028273 with pick code, then date stamped on 2nd line.
Each style of original '69 RA Qjet had its own style of font for the stamped numbers. Lot of very expensive forgerys out there, & honestly, unless one truly knows what he's looking at, the chances of getting burned are very high.
-Very very late in '69 production, several '69 RA3 stick cars have been documented as using the RA4 application 7029273. This particular RA Qjet are even more expensive & there are numerous forgerys out there as well.
Unless the car is deserving of a cutting edge Concours restoration, it would be much more sensible & much more affordable to search out a Service Replacement dated 7029270. The SR dated 7029270 Qjets were Service Replacement for all three '69 Pontiac Ram Air Qjets. Typically, '69 RA SR Qjets trade in the $500-650 range, needing restoration. Real deal 28273's & 7028273's are well over 2K, needing total restoration, if one can find one. Again really, have to know what ones looking @ if pursuing the real deal.
post #4 of 4 (permalink) Old 11-23-2016, 10:01 PM Thread Starter
Quoted: 17 Post(s)
Thank you. Great info
Ram Air carb Roger that 1964-1974 Tempest, Lemans & GTO General Discussion 9 03-03-2019 04:22 PM
70 gto non ram air to ram air 1970gto455conv 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 4 09-05-2014 06:12 PM
can you turn the ram air hood into a functional ram air? court_jester06 Intake and Exhaust Discussions 12 07-25-2010 02:36 PM
1968 Ram Air Carb Pan ..... ramairthree 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 04-04-2009 06:52 PM
