70 GTO fuel vent routing - Pontiac GTO Forum
post #1 of 2 (permalink) Old 10-22-2015, 04:03 PM Thread Starter
how do they route at rear frame, no canister, 1 half inch line on tank and 1 quarter inch line from pump, quarter inch at neck thats OK and main fuel line 2 metal lines run top of crossmember?
montanarod is offline
post #2 of 2 (permalink) Old 10-22-2015, 07:06 PM
Quoted: 367 Post(s)
The 1/4" line from the fuel pump is a return line going back to the gas tank. The 1/4" nipple on the gas filler neck is for the tank vent line, not a fuel return line. The vent line vents to the atmosphere. Believe the return line from the fuel pump goes to the gas tank and you should find the fitting at the top front of the tank. If the tank has been replaced, it is possible that the fitting for the fuel return line may not be there.
Most fuel lines are 3/8", you said 1/2". Are your lines 1/2" and do you have a custom/replaced gas tank?
Check the online Ames downloadable catalog. I believe they have a diagram for this. They also list the gas tank vent parts.
PontiacJim is online now
Fuel Line Routing along Frame Rail, 69 Vert/Judge GTORAD 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 3 06-25-2015 11:44 PM
'67 GTO Brake Line Routing Help chainboy1 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 2 05-29-2015 12:57 PM
Fuel Pump Vent Line Tony Morillas 1964-1974 Tempest, Lemans & GTO General Discussion 3 07-28-2013 05:25 PM
Fuel and Brake line routing on 66 Convert Spanky64 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 2 01-29-2012 07:07 PM
Fuel Sending Unit: with or with out vent yousaygo 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 04-27-2010 07:58 AM
