'71 hood vent ornaments-scoops - Pontiac GTO Forum
post #1 of 8 (permalink) Old 12-26-2010, 02:18 AM Thread Starter
Alaska71's Avatar
This is my first post on ANY forum. I'm new to GTO's, and I just purchased a 71 and I'm pretty tickled. The first thing I noticed was that the front hood vents don't line up cleanly. (I've removed them and it appears that there is a spacer, maybe stacked washer behind them on the mounting bracket. ) They just don't come up cleanly against the upper hood opening, and that has me bugged. Most of the photo's I've looked at show there IS an up to 1/4 in. space or misalignment there, then others show nice clean lines where the upper edge of the vents meets the hood opening. Do I simply live with it, start sanding the hood, get a life? Any ideas/opinions are greatly appreciated...Thanks, Steve.
Alaska71 is offline
post #2 of 8 (permalink) Old 12-26-2010, 06:10 PM
Welcome to GTO's.
Nobody will notice this gap as your blowing thier doors off.
dimitri is offline
post #3 of 8 (permalink) Old 12-26-2010, 09:21 PM
Quoted: 23 Post(s)
Welcome Alaska, if they are repro's they are notorious for bad fits, don't know if i would grind the hood, would more likely try to adjust and shim mounts to get an even gap and call it good.
Instg8ter is offline
post #4 of 8 (permalink) Old 12-27-2010, 01:03 PM Thread Starter
Alaska71's Avatar
Thanks, they are stock, but I just noticed a small 'tab' hanging down on the hood on one side that holds the entire peice down along it's length. I have decided to VERY carefully remove the offending tab and perhaps 1/64 at a time along the bottom edge...I'll take B-4 and after photo's and post later. Thanks. It's -20 here and I can't even drive it until about May 1st anyway....I got time. THANKS !
Alaska71 is offline
post #5 of 8 (permalink) Old 12-27-2010, 01:07 PM Thread Starter
Alaska71's Avatar
I like your style. I CAN carefully remove a small tab that shouldn't be there and with carefull filing I can improve the fit a bit. Plus shims in the right spot...Too bad I'm not close to 101.....blast up to Petaluma and back. Thanks.
Alaska71 is offline
post #6 of 8 (permalink) Old 12-27-2010, 02:10 PM
Quoted: 23 Post(s)
WOW!! somewhere colder than Michigan...I feel your pain Alaska, have a brand new motor i am dying to get in mine and fire up for breakin, holding off until a little closer to thaw so i don't set the rings listening to it purrrr in the garage...lol. let us know how it comes out, trouble shooting 101 K.I.S.S. (Keep It Simple Stupid), hoods are too expensive to go grinding at, and remember these are not Bentley's, sometimes the parts just don't fit right w/o a little persuasion.
post #7 of 8 (permalink) Old 12-27-2010, 04:39 PM
I just spent xmas at my sisters house. She lives in "Chickaluma".
dimitri is offline
post #8 of 8 (permalink) Old 12-27-2010, 10:14 PM
Thor7352's Avatar
Welcome to the forum!! sounds like a nice car.
Keep in mind, a picture is worth a 1000 words.. and we all love drooling.
Thor7352 is offline
Hood Scoops GhostRider 2004-2006 GTO General Discussion 8 04-25-2014 01:54 PM
hood hinges/ vent windows johnnylightning03 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 42 03-26-2010 07:20 PM
Hood scoops BlckGTO04 Exterior Discussions 6 07-01-2006 07:29 PM
Hood Scoops michaelskier 2004-2006 GTO General Discussion 4 03-24-2006 06:54 PM
Hood Scoops GTODAVE05 Service, Maintenance and Technical Discussion 7 05-18-2005 12:17 PM
