71 lemans timing cover - Pontiac GTO Forum
post #1 of 6 (permalink) Old 10-05-2012, 12:52 PM Thread Starter
Hi all I am new to this forum and have run into some difficulty with the front timing chain cover. Two of the studs that go through the water pump and through the timing cover into the block are broken off. These are the top 2 timing cover bolts by the water pump sleeves. Seems like a basic straight forward stud through the timing cover but the cover will not budge at all. I just want to make sure I am not missing anything here.
Any help would be great. This is my first time trying to rebuild a pontiac engine.
kevinpagano is offline
post #2 of 6 (permalink) Old 10-05-2012, 06:38 PM
Icefan71's Avatar
Do you have all the water pump and timing cover bolts removed? There are bolts at the bottom going through the oil pan. Then you can use a putty knife or something to break it free. Oh and the fuel pump has to come off too.
Icefan71 is offline
post #3 of 6 (permalink) Old 10-05-2012, 07:11 PM
jetstang's Avatar
My bolts through the pump to the block were corroded in, I had to drill them out. It ruined the cover. The aluminum front mid section can be a pain. Good luck.
Burning rubber since 1982!!
jetstang is offline
post #4 of 6 (permalink) Old 10-06-2012, 08:38 PM
Betting it's the front 4 bolts on the bottom of the oil pan....
post #5 of 6 (permalink) Old 10-08-2012, 10:44 AM Thread Starter
Thanks for the replies. Yes the oil pan and front harm balancer is removed so no bolts left to remove as I can see. unless there is something really hidden. I think its corrosion and that is why the to bolts broke off. I am afraid I will have to get the cutting wheel out and cut the front cover off as much as I hate to do that.
post #6 of 6 (permalink) Old 10-16-2012, 01:02 AM
double check that 4 bolts under the front lip of the timing cover are off. Feel around with your fingers the very front sections of the oil pan. Real easy to miss, even if you know they're there, and just forgot about them. Just went through this last night. Knew they were there. No harm done, though.
gjones is offline
timing cover 428 Chris-Austria 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 14 07-19-2012 07:23 PM
Timing cover mikey gto 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 1 05-25-2012 11:08 PM
Timing Cover GoatJoe 1964-1974 Tempest, Lemans & GTO General Discussion 11 05-28-2011 03:05 PM
