aftermarket hoods - Pontiac GTO Forum
post #1 of 20 (permalink) Old 03-11-2015, 09:14 PM Thread Starter
aftermarket hoods
Not sure whether to use/repair my 66 hood or not, anyone use an aftermarket GTO hood and how did it fit? What was the quality? And, would you buy that hood again if needed?
Thanks.
66242 is offline
post #2 of 20 (permalink) Old 03-12-2015, 05:29 AM
All of the aftermarket sheetmetal I have used has been thin, the wrong size, and wavy. It does have two saving graces: it's coated in epoxy, and it's cheap. But either aftermarket or original, you're going to end up working on the piece.
ibarbuckle is offline
post #3 of 20 (permalink) Old 03-12-2015, 06:20 AM
rickm's Avatar
Quoted: 5 Post(s)
an original hood scoop insert usually will not fit right with an aftermarket hood n visa-versa. you would have to buy a aftermarket insert also.
rickm is offline
post #4 of 20 (permalink) Old 03-13-2015, 09:26 PM
Aftermarket OK this time
I put one of those ADEALS ebay hoods on my 68 and its perfect.Not a wave,or any imperfection at all and perfectly square same weight as the original... maybe I got lucky
frankrp is offline
post #5 of 20 (permalink) Old 03-14-2015, 02:34 PM
GTO70455's Avatar
Got a aftermarket hood for my 1970 GTO from Ames and it was perfect. No fitment problems!
GTO70455 is offline
post #6 of 20 (permalink) Old 03-15-2015, 03:11 PM Thread Starter
Sounds like mixed reviews, I'd hate to take a 400.00 chance on a bad fit.
Thanks, Jay
66242 is offline
post #7 of 20 (permalink) Old 03-21-2015, 10:50 AM
I have a stock 66 in great shape if interested?
FMFC motorsports is offline
post #8 of 20 (permalink) Old 03-21-2015, 01:43 PM
Quoted: 100 Post(s)
The '65-'67 aftermarket hoods are the ones with issues. The area around the scoop is not the same, as stated, and the scoop bulge is not the same shape around the edges where it meets the hood. Better off with a used original part if it's a '65--'67 goat.
post #9 of 20 (permalink) Old 03-22-2015, 02:59 PM
Originall '68, and '69-70 GTO hoods also have differences from the repro.
'68 hoods have differences in the inner structure, as were not designed to fold up in a frontal collision. instead, the rear corners of original 68 hoods often went back into the windshield.
'69 hoods had revised understructure, so they would fold up, and are separated into standard hoods and RA versions. Original production '69-70 RA hoods with factory hood tachs originally had a piece of the understructure trimmed by a portable hydraulic sheer. This small area was removed in one continous clamping of the tool...not the easiest to replicate with a saw or grinder if restoring a high point car, but it can be done. Last, have not ck'ed a one fits all "68-70" repro GTO hood in some time, but for at least the first 10 years of production, the ironing board center area of the repro hood was not as defined as an original or even an NOS '70 hood, and the repro had to have filler work and careful sanding to get it close.
post #10 of 20 (permalink) Old 03-22-2015, 03:18 PM
crustysack's Avatar
my aftermarket 65 hood had really good fitment, it was wavy and needed pro paint attention( just like an original) but the edges where fine and it bolted right in. I did buy a repo insert and had zero problems
crustysack is offline
Hoods? SnKGoat Exterior Discussions 3 12-05-2006 01:31 PM
In Da Hoods BitterGenius 2004-2006 GTO General Discussion 1 08-21-2006 09:11 PM
'05 Hoods Country Boy Service, Maintenance and Technical Discussion 6 07-25-2005 07:20 AM
More on aftermarket hoods (for us 04 GTO guys/gals) MaxHax 2004-2006 GTO General Discussion 15 01-20-2005 05:16 PM
hoods badtmpdgoat 2004-2006 GTO General Discussion 17 01-09-2005 03:41 PM
