Axle shaft difference Help - Pontiac GTO Forum
post #1 of 3 (permalink) Old 05-03-2012, 12:02 PM Thread Starter
FlambeauHO's Avatar
Quoted: 8 Post(s)
Noticed when I picked up my rear end today that one of the shoulders for the bearing (the old axle shaft's) is about .25" higher than the other. Other than that, dimensions are the same. This would push 1 wheel out .25"...
Any thoughts? Any other fitment issues? Rear end is way over budget.
FlambeauHO is offline
post #2 of 3 (permalink) Old 05-03-2012, 08:12 PM Thread Starter
FlambeauHO's Avatar
Quoted: 8 Post(s)
Going to take this back to the guy who built my rear on Monday. The only fix I can think of is to put a spacer on before the bearing ...
post #3 of 3 (permalink) Old 05-04-2012, 04:23 PM
Quoted: 98 Post(s)
Yeah, or get the right axle. The bearing has to be where the original one was, so that it can seat in the right position in the axle housing. Otherwise, it won't be sitting all the way in place on the machined lip, and won't have good support.
Need a 10 bolt axle shaft FlambeauHO 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 13 04-17-2012 04:47 PM
GTO Axle shaft insertion Hi Po GTO 1964-1974 Tempest, Lemans & GTO General Discussion 3 05-18-2010 01:56 PM
Broken Axle Shaft thull97 Drive train, suspension, alignment and brakes. 3 11-14-2009 12:11 PM
cam shaft kit dallas64 Engine Discussions 9 06-25-2008 12:09 PM
Drive Shaft Stamp235 Drive train, suspension, alignment and brakes. 5 07-29-2007 01:43 PM
