Best Adhesive for woodgrain - Pontiac GTO Forum
post #1 of 3 (permalink) Old 04-20-2014, 01:57 PM Thread Starter
I have everything disassembled, cleaned and the wood grain vinyl adhered to the steel backings. Now I have to adhere them to the console top so the question is what to use for the adhesive. Can you guys make any recommendations for what to use? Feedback is appreciated!!
chemnick is offline
post #2 of 3 (permalink) Old 04-20-2014, 04:22 PM
3M spray adhesive should do the trick.
post #3 of 3 (permalink) Old 04-21-2014, 08:10 AM
I concur on the 3M, but if that's not available then good old-fashioned contact cement will do. Mix it well and roll on a conservative amount. Let it dry per directions and keep it about 1/4" away from the edges so it doesn't become a dirt trap that won't clean up.
666bbl is offline
Dashboard woodgrain, Best replacement? No Goat 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 02-21-2013 09:26 PM
Fuel Door Gasket: Which Adhesive? GM Kid Service, Maintenance and Technical Discussion 6 05-28-2012 10:49 PM
trying to remove adhesive under vinyl roof pbertrand65GTO 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 11 01-23-2012 03:51 AM
Success! Got adhesive off roof. pbertrand65GTO 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 0 01-15-2012 08:18 AM
Replacing woodgrain dash blondie67 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 12 03-27-2008 07:47 AM
