best undercoating for 66 GTO - Pontiac GTO Forum
post #1 of 9 (permalink) Old 06-09-2015, 02:56 PM Thread Starter
what is best undercoating product for my 66 GTO?
ottfive is offline
post #2 of 9 (permalink) Old 06-09-2015, 07:20 PM
I used 3M's paintable undercoating on my 66, it has been 7-8 years and it's holding up well.
3M Paintable Undercoating 08882
05GTO is offline
post #3 of 9 (permalink) Old 06-09-2015, 09:17 PM
Paint, it holds up fine. And if it does show wear; sand/scuff, mask, and paint.
younggto is offline
post #4 of 9 (permalink) Old 06-09-2015, 09:39 PM
No undercoat, except a slight misting in the rear wheel wells in same areas as factory. Undercoating, bedlining material, etc adds weight and screams "puppymill build" = trying to hide something.
On bare underbody, I use Master Series, holds up better than epoxy paints, stumbled onto it as can't get real DP90 anymore.
post #5 of 9 (permalink) Old 06-10-2015, 04:00 PM
DSMTiger's Avatar
+1. Don't undercoat unless you are hiding something.
1966 TriPower, 4 spd, PHS documented.
DSMTiger is offline
post #6 of 9 (permalink) Old 06-10-2015, 05:18 PM
bobby326's Avatar
If your not going for concorce and just doing it gor better pertection i use rspyor bedling and thinned it out with laquor thinner. Worked very well and looks very good. Bout $90 a kit and one kit will do entire underneath of car. I did entire underneath snd entire inside floors and trunk of my 67.
bobby326 is offline
post #7 of 9 (permalink) Old 06-11-2015, 12:43 PM Thread Starter
Thanks for all the info. just want a good coating to protect metal, not hiding anything
ottfive is offline
post #8 of 9 (permalink) Old 06-11-2015, 01:48 PM
3M doesn't hide anything, has a semi smooth texture and works as a great sound deadener.
05GTO is offline
post #9 of 9 (permalink) Old 06-16-2015, 03:00 PM
Quoted: 100 Post(s)
What O5 said....if you want to do it, use the 3M. Not too thick and it can be removed with mineral spirits. My '65, a CA car, has nothing but paint, and looks new still. My '67 came from Tenn., and was Ziebarted when new. Good thing, because if it hadn't been, it would need all new floorpans. It's been in CA since 1983, but I've left it alone. It's still doing its job. Depends on where you are and how you drive.
POR15 Undercoating Spray Josh.AZ.GTO 1964-1974 Tempest, Lemans & GTO General Discussion 10 12-30-2012 02:55 PM
Removing rubberized undercoating? vikeman 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 08-19-2010 10:47 PM
Undercoating injn37 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 04-23-2009 04:36 PM
Undercoating blondie67 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 06-19-2008 07:47 AM
undercoating? kwiktsi 2004-2006 GTO General Discussion 7 04-20-2006 08:39 PM
