Body mount bushings - Pontiac GTO Forum
post #1 of 9 (permalink) Old 09-25-2012, 07:52 PM Thread Starter
Body mount bushings
I bought a kit but don't know how to install the bushings on #3 mount. The Pontiac shop manual says that the #3 uses a different bushing but the kit I bought has all the same bushings. The mounting hole is smaller on #3, so the bushings won't fit down in the hole. My car is a '65. Any help would be great.
orelog is offline
post #2 of 9 (permalink) Old 09-25-2012, 08:53 PM
Pontiac Restoration guide?
Have you looked in Zazzarine's Restoration guide book?
I have it, I can try to look it up for you if you dont have it.
I have a 65 GTO that is currently off the frame, so I'd like to know
that myself.
I generally only check this board 1-2x/week, so if I don't get right back to you, that's why.
Paul
SlamminGears65Goat is offline
post #3 of 9 (permalink) Old 09-26-2012, 11:33 AM
68Resto-mod's Avatar
The bushing kit that came in for my 68 also had all the same bushings. The manual shows different bushing types as well. Difference is, all my frame holes are the same size.
Have you considered just opening up the #3 holes?
Lance
68Resto-mod is offline
post #4 of 9 (permalink) Old 09-26-2012, 01:27 PM
68greengoat's Avatar
Lance
I changed the bushings in my '68. Purchased the kit from Performance Years. Everything fit perfectly...
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #5 of 9 (permalink) Old 09-26-2012, 03:10 PM
FlambeauHO's Avatar
Quoted: 8 Post(s)
Got my kit from Ames, no problems and I believe they were all the same on my 68.
FlambeauHO is offline
post #6 of 9 (permalink) Old 09-27-2012, 08:57 PM Thread Starter
Body mount bushings
The 1965 frame is different from the later years. The holes on the later years are all the same. The problem with the kit is, it universal for 64-67. I don't want to open up the holes. If anything, I will modify the bushings.
orelog is offline
post #7 of 9 (permalink) Old 09-28-2012, 11:47 PM Thread Starter
Body mount bushings
I talked to the supplier today and they said that some of the earlier frames at some of the different plants had a smaller hole in the #3 mount. No one makes a bushing for this hole because the demand is so small. I modified my bushings with a dremel tool with an abrasive disc and they fit just fine now.
orelog is offline
post #8 of 9 (permalink) Old 11-07-2015, 11:06 AM
Hello
Where did you get the kit from and is it rubber or poly??
I am restoring a 1964 GTO
I would like to get the poly but I can't find a kit with bolts. They make one for the 64Chevelle but not GTO does anyone know the difference between the two????
jimterriesser is offline
post #9 of 9 (permalink) Old 11-08-2015, 08:56 AM
Hello
65 Gto body mount repair zzomby 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 14 04-04-2012 04:14 PM
Body mount questions TK69tempest 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 02-28-2011 08:15 PM
65 Gto Body Bushings zzomby 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 09-20-2010 03:22 PM
Body Bushings ChromeShopJoe 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 08-06-2009 02:32 PM
69 GTO Body Bushings WillieF 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 05-06-2008 06:16 AM
