Body mount question - Pontiac GTO Forum
post #1 of 4 (permalink) Old 09-17-2018, 12:38 AM Thread Starter
Fxnjetz56's Avatar
Body mount question
Just forward of the rear spring perch is a rubber pad/mount. Is this actually considered a body mount? Included in most kits? Or is this something different?
Thank You.
Fxnjetz56 is offline
post #2 of 4 (permalink) Old 09-17-2018, 06:37 AM
GTOJUNIOR's Avatar
Quoted: 68 Post(s)
That is considered a mount, some of the bushings used were solid, what I call pucks.
That one looks odd almost as it is one the wrong side of the chassis?? but had to tell from the pic.
Below is a factory photo of a '66 chassis for reference, clearly showing all the body mount locations, however they all look to be bolt through types.
Either could have been used at that location as well as the forward most mounting point on the inner location.
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #3 of 4 (permalink) Old 09-17-2018, 08:14 AM Thread Starter
Fxnjetz56's Avatar
Thanks, your pic shows it perfectly. In my photo from beneath, you are seeing the bottom of that pad where it protrudes into its mounting boss. It does not appear to be bolted in however, just sitting atop that spring perch.
post #4 of 4 (permalink) Old 09-17-2018, 05:29 PM
GTOJUNIOR's Avatar
Quoted: 68 Post(s)
OK, that mount just looked funky in your pic.
Some of the cars I've come across had 4 solid mounts (PUCKS) while others just had the bolt through style,
either would work just not bolts for those four.
I've circled the mounts that are usually solid.
There are 2 kits on the market, one with the 4 solid mounts and the second is all bolt through.
Name:	BODY MOUNTS.jpg
ID:	115469   Click image for larger version
Name:	BODY MOUNT KIT 1.jpg
ID:	115471   Click image for larger version
Name:	BODY MOUNT KIT 2.jpg
69 judge body mount question greenjudge69 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 09-13-2015 09:02 PM
body mount question/ rally 2 question greenjudge69 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 5 04-13-2015 10:28 AM
Body mount and radiator support bushing question topfuel67 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 09-10-2014 02:51 PM
Body Mount Bushing question Fred007 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 7 01-08-2011 11:41 AM
Body Mount Question Fred007 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 06-10-2009 09:37 PM
