Body work questions - Pontiac GTO Forum
post #1 of 14 (permalink) Old 09-15-2011, 10:49 AM Thread Starter
jigaway's Avatar
Body work questions
If I have some rust on my deck lid and hood, generally along some seams, is it best to toss those items and try to find newer ones with no rust apparent?
To better clarify this, it was suggested to me that I do replace since the rust may be within the metal seam and will continue to come out even after painted.
The deck lid has some rust showing along the trailing edge, running from one side to the other.. Other than that, the lid is mint in shape and appearance. Can that rust, seemingly from inside, be repaired?
thanks in advance,
Dan
jigaway is offline
post #2 of 14 (permalink) Old 09-15-2011, 11:07 AM
Anytime there's rust, you want to get rid of it, especially before you paint. If it's repairable, I would try that before replacing whole panels.
BForbes is offline
post #3 of 14 (permalink) Old 09-15-2011, 01:47 PM
Thumpin455's Avatar
Got any pics of what you are talking about? How bad it is decides if the panel needs replaced or patched. Also what some people would toss is perfectly ok to start out with to me, but even I have limits.
Depending on where it is you have a few options, including POR, rust converters, sandblasting, and patches. Take some pics of it and post them, then we can tell you how best to proceed.
Thumpin455 is offline
post #4 of 14 (permalink) Old 09-15-2011, 02:21 PM Thread Starter
jigaway's Avatar
Thanks for the response. I will take pics. Right now she is with the resto-man who is pulling/repainting the einge/trans/engine bay. He knows I want to do things right, so he mentioned he saw rust along the trailing edge of the truck lid. He seemed to think it might be systemic and moving along the seam.
I figure, the alternative is to seek out another 40 yr old deck or hood and see what problems and rust it has or doesn't have?? Which doesn't seem right. Good gosh I've seen pictures on this board and others of completely rusted out frames that people have rebuilt. Hopefully I am overreacting.
Dan
jigaway is offline
post #5 of 14 (permalink) Old 09-15-2011, 06:05 PM
66tempestGT's Avatar
pics would be needed. are you talking about some orange color and a few bubbles or do you mean holes. most of the panels on these old cars are put together without primer so some rust is gonna happen in the seams especially. dont panic it sounds like you are talking to someone thats used to working on newer cars.
Shane Doss
66 tempest
64 el camino
02 mullis dragster
66tempestGT is offline
post #6 of 14 (permalink) Old 09-15-2011, 06:54 PM Thread Starter
jigaway's Avatar
I'm looking at orange color, splitting below the paint along the trailing deck edge. My resto guy seems to think it needs to be replaced. I think he might be an over perfectionist.. I tempestsearched for hood and deck lid and found a few rusty odd looking ones hundreds of miles away. Def not worth the trip. Will post a few shots of the rust tomorrow after I visit the car.
Still wondering if this dip/curl on the leading tip of the hood can be straightened?
jigaway is offline
post #7 of 14 (permalink) Old 09-15-2011, 07:42 PM
Thumpin455's Avatar
What I would do to fix the hood is make a cut or two, recontour it so the lines match, and refinish it. That is only something I would do if I were building a car that simply had to have perfect gaps, and everything lined up exactly. If its a driver, that isnt a problem like it is, since its a 40 year old car now. The T41 front end never fit well when new, and getting one perfect is going to take time, patience, and money. If I can get my daughters 72 with a 71 front end to line up as well as yours, I will be happy.
post #8 of 14 (permalink) Old 09-15-2011, 10:21 PM
i would try to lower the center of the bumper a little. i agree it probably looked about like that when it was new.
Shane Doss
66 tempest
64 el camino
02 mullis dragster
post #9 of 14 (permalink) Old 09-16-2011, 07:12 AM
A good metal man could fix that hood curl. Rust is NOT magic. Find it, cut it out, replace the metal, seal and continue to march! I have just gone through it all........ The hardest part of the fix, is matching the paint at the repair site. Eric
Eric Animal is offline
post #10 of 14 (permalink) Old 09-16-2011, 07:05 PM Thread Starter
jigaway's Avatar
My car was is in a garage so the camera couldn't pick up real well expecially against white paint. Photoshopped the contrast and brightness best I could.
Here is the back edge of the deck lid. It is bubbly, along the length on the inside (of trunk) edge. About 2-3 inches wide running the entire length of the lid. My resto guy thinks whoever did it was poorly trying to hide a bunch of rust which is seeping through. It is full of putty and rust bubbles etc.. Other than this crappy area, the lid seems mint.
Any body/rust experienced members think this lid can be saved or should I seek another?
And yes, it's not as bad as I thought...
Dan
jigaway is offline
starting body work Instg8ter 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 34 01-14-2011 08:59 PM
Vinyl top and body work blondie67 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 9 03-28-2008 06:18 PM
Body Work DallasSleeper Exterior Discussions 11 02-14-2006 12:46 PM
Need body work advice Legionaire Service, Maintenance and Technical Discussion 0 02-08-2005 07:00 PM
