Bring me up to speed - Pontiac GTO Forum
post #1 of 9 (permalink) Old 06-05-2014, 11:22 AM Thread Starter
I've been away from my Pontiacs for over 20 years, and now have time to get back to work on them, and I need to be brought up to speed on a couple of things.
Has anyone ever come up with a high heat paint or powder coating in Pontiac metallic blue that won't burn off of the heads at the cross over and exhaust ports?
Does anyone sell replacement quadrajets that don't require a core?
Are there any good swap meets that I can locate parts for Pontiacs?
Thanks, Bo
Stepp on it is offline
post #2 of 9 (permalink) Old 06-05-2014, 11:46 AM
Pontiacpurebrred's Avatar
Thanks, Bo
Hey Bo,
First welcome!
I will jump in, I started back about 25-30 years ago with Pontiacs, been gone and come back a few times so I know what you must be going through. First, no to my knowledge there is no paint (or process) that stands up to the heat of the heads. That said there are now aluminum cylinder heads available for Pontiac engines that I have heard can be painted with better results - I am sure Bear will jump in with his feedback about that.
Your best bet for parts is now Ebay, Craigslist.org, local meets and swap n shops and that sort of thing. As far as I know any service that sells quadrajets will require a core, your best case would be someone that offered a huge discount with a core or a much higher price no core.
You have come to the right place for answers, and there are A LOT more resources now than 20 years ago. I know sometimes I feel like a kid in a candy store.
Good Luck,
Scott
2005 GTO Daily Driver
1969 Custom-S Project car
1971 GTO 455 in process of rebuild TH400 NEED A NEW REAREND!!!
Pontiacpurebrred is offline
post #3 of 9 (permalink) Old 06-05-2014, 01:30 PM
Bo, Plasti-Kote paint is what Ames sells. I've used it and I think it is pretty good. That said, I do have a browning effect at the points you reference. Summit does sell Quadrajets that do not require a core. About $500. I bought a stage 2 from them and am happy with it. Not sure on the swap meets coming up. Matt
Matthew is offline
post #4 of 9 (permalink) Old 06-05-2014, 02:53 PM Thread Starter
I'm doing a true restoration on my convertible, so no Edelbrock heads for it.
I have a hardtop that I'm thinking of making more of a driver, so I may go that way with it.
The only quadrajets I can find are side inlets for a Chevy, which wouldn't be correct.
I will eventually find one.
post #5 of 9 (permalink) Old 06-05-2014, 03:13 PM
pjw1967's Avatar
I have one or two bones to pick with Ames. That said the qjet I bought from them a year or so ago has performed flawlessly. Right out of the box. No adjustments. They promised me that it was rebuilt with ethanol resistant gaskets etc. I did not return a core. Yes that cost me but I wanted to hang onto it just in case. Good luck.
pjw1967 is offline
post #6 of 9 (permalink) Old 06-05-2014, 06:34 PM
Quoted: 117 Post(s)
Burnt paint on the exhaust ports and intake heat areas is a badge of honor: it means you drive your Pontiac and it's not a trailer queen. Nature of the beast. Doesn't bother me a bit. Any more than having the tits on my new tires worn off due to driving. No big deal.
post #7 of 9 (permalink) Old 06-05-2014, 06:47 PM
1968 GTO / 400 HO / 4 Speed
Pat68HO is offline
post #8 of 9 (permalink) Old 06-06-2014, 07:09 AM
Bo, looks like OPGI has stage I and II quadrajets advertised... with the correct fuel inlet. Matt
Matthew is offline
post #9 of 9 (permalink) Old 06-06-2014, 07:58 AM
SANDU002's Avatar
POR 15 makes a Pontiac engine paint I used with good results. As stated above, a little burning is a sign of what these cars are all about.
67 Post Coupe,
69 RA III Judge
06 BOM, M6, 18's
SANDU002 is offline
Bring back the Paint abodybrad 1964-1974 Tempest, Lemans & GTO Paint Shop Discussions 2 01-14-2009 09:17 AM
I wish I could bring my work home with me PEARL JAM The Lounge 5 06-25-2007 02:45 PM
Do you think the 05's will bring more people to this board? Redline 2004-2006 GTO General Discussion 3 09-29-2004 05:56 PM
