Building 461 Stroker reuse any parts? - Pontiac GTO Forum
post #1 of 3 (permalink) Old 05-09-2012, 07:07 PM Thread Starter
jtwoods4's Avatar
I am building a 461 stroker from my original 1969 400 block. The block is going to the machine shop tomorrow to get cleaned up and prepared for the new stroker kit. Should I also send the timing cover to the shop? Is this something that can be re-used in a rebuild or should I buy a new one?
Sent from my HTC Vision using AutoGuide.Com Free App
jtwoods4 is offline
post #2 of 3 (permalink) Old 05-15-2012, 10:35 AM
Josh.AZ.GTO's Avatar
There are a few on this forum who built 461 stroker motors. Bear is one of them. He would have a wealth of knowledge about building this engine.
JOSHUA
1970 GTO 455HO Cardinal Red
Josh.AZ.GTO is offline
post #3 of 3 (permalink) Old 05-16-2012, 09:12 AM
Hey jt,
Definitely reuse all the external parts like the timing cover, etc, that you can. If it's in good condition and the coolant tubes are in good shape (not corroded, stuck, etc) there's not a reason in the world not to reuse it. Make sure you put a fresh seal in it, use good gaskets, set the water pump plate clearance while you have it apart, etc.
Building up my 05 GTO GonzoTakesOff 2004-2006 GTO General Discussion 7 12-10-2011 06:58 PM
building the 700r4 ... and stuff 67TEMPtress 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 11-19-2010 06:20 PM
Building a GTO drift car drftmonkeyauto 2004-2006 GTO General Discussion 8 02-22-2010 08:28 AM
Building 428 for 69 GOAT arch&69 Engine Discussions 0 07-09-2006 08:48 PM
Is Building a GTO still an option? Copenhagen848 2004-2006 GTO General Discussion 7 04-23-2005 03:23 AM
