cam replacement - Pontiac GTO Forum
post #1 of 3 (permalink) Old 05-02-2016, 08:56 PM Thread Starter
vera_jr's Avatar
cam replacement
How difficult is it to replace a cam and lifters in a 69 gto 455?
I am pretty good mechanically, but I am by far not an expert. I would like to just take the engine out and send it to a machine shop and have the whole thing rebuilt, but I dont have those kind of funds.
vera_jr is offline
post #2 of 3 (permalink) Old 05-04-2016, 05:29 PM
Quoted: 368 Post(s)
Its not so much how difficult it is, the reply question to you is "Do you have a factory chassis manual to guide you in the removal & installation, do you have the correct tools, and IF you get yourself in trouble can you fix/repair the problem?"
I would suggest you first do much reading on how this is done. Then you might need to understand and have the tools to check your cam bearings to ensure they are not worn or out of round. No need to go any further with the installation as at that point the machine shop isn't an option - its a must. You might also want to check your lifter bores for wear and out of round - again, any problems here and its machine shop time.
Keep in mind that depending on what type of cam, ie duration & lift, you can get yourself into trouble with valve to piston clearances. You don't want a valve kissing the piston top. If you keep your lift stock, then less chance of any problems, and you can play around with the LSA and valve closing degrees. You also want to ensure you don't over cam your engine so you will need to know compression. Matching your cam to your drivetrain components is also a very important step in selecting an appropriate cam - and many overlook this and get disappointing results.
Selecting a cam that builds more dynamic compression will put more pressure to the ring seal, so your rings gotta' be good or you'll be getting additional blow-by or oil burning.
As you can see, many factors (and these are just a few to consider) have to be taken into consideration if you plan on doing a cam swap. Not saying you can't do it and not saying you will have any problems or issues, BUT, you should be aware of a few things that you could run up against and bite you in the butt.
Personal suggestion would be to forget about the cam swap at this time and save your hard earned money until you can properly do an engine rebuild and match all your new parts so everything works in harmony without any fears.
post #3 of 3 (permalink) Old 05-04-2016, 06:34 PM
Pontiac Jim is right on the money. The cam affects so many things in an engine. When I was spec'ing out my stroker build, I came to realize how everything is interrelated. My head was really spining when it came to do the cam specs.
My advice would be to look for tried and true combinations that people have tested out. Several Pontiac Engine books have good designs listed in them and guys here have rebuilt a lot of them.
As for the physical aspect of replacing the cam, it's not hard. But I agree that the bearings should be looked at as well as the block if possible. And as Jim said, understanding the relationships involved with timing, lift, clearances, etc is VERY important.
BierManVA is offline
LS1 stock cam VS LS2 stock cam Ehrgeiz X 2004-2006 GTO General Discussion 5 02-14-2014 05:20 AM
direct replacement? nrizzo04 Drive train, suspension, alignment and brakes. 4 04-22-2012 06:28 AM
Looking for near stock cam replacement supercab78 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 6 11-19-2011 02:51 PM
Cam Chose ms4 vs livernois strage 2r cam GTOMOE9 Engine Discussions 7 03-08-2011 10:20 PM
Best Replacement Cam Kit jbranontn 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 4 03-14-2009 10:48 AM
