Console Vacuum Gage - Pontiac GTO Forum
post #1 of 2 (permalink) Old 04-22-2011, 10:23 AM Thread Starter
Purple Haze's Avatar
Console Vacuum Gage
I picked up the console mounted vacuum gage for my 65. Is there a template or does anyone know exactly where they are mounted?? I also still need the light harness. Any help is appreciated, thanx,
Ric
Name:	vac console gage.jpg
Purple Haze is offline
post #2 of 2 (permalink) Old 04-22-2011, 11:25 AM
Remove the console and turn it over.....you will see a square hole in the plastic, in front of the shifter, and center......the gauge mounts over the hole and the wire and vacuum line are routed through it......M&H wiring sells the light repro. It is connected into the harness so the gauge lights with the dash lights. There is a small oval bezel that mounts between the gauge bottom and the console top, if you don't have one the resto companies sell them for about $27 Eric
Eric Animal is offline
Vacuum Gage placement????? Rowdygto 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 28 10-02-2014 07:26 AM
dash gage opening color 68GTO4004Spd 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 7 03-25-2011 02:40 PM
AC Vacuum lines SIXT5GTO 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 0 03-19-2011 02:12 PM
Vacuum Gage placement????? Rowdygto Gtoforum.com Site Help 1 10-12-2008 10:09 AM
