Converting my 69 GTO to hideaways, am I missing anything? - Pontiac GTO Forum
 1Likes
  • 1 Post By tooth
post #1 of 7 (permalink) Old 06-21-2017, 03:45 PM Thread Starter
Js1969's Avatar
Quoted: 5 Post(s)
I always loved the looks of the hideaway headlights and wanted to add them to my GTO since it wasn't 100% original anyways. I have tried to order everything needed. I tried to find a site that would list everything needed but came up short. The below list is everything I have ordered, if you notice anything missing please let me know. All parts have been purchased through OPGI.
GTB0017 Headlamp, Actuator, Hideaway, 1968-69 GTO
GTB0015 Door Saver, Hideaway Headlamp, 1968-69 GTO
KR20026 Door Cover, Hideaway Headlamp, 1969 GTO , Right
KR20026 Door Cover, Hideaway Headlamp, 1969 GTO , Left
G240803 Headlamp, Hideaway, 1968-69 GTO, Assembly, Right (Rod assembly for tilt drive torsion – Reinforcement for headlight tilt door – Support for tilt drive torsion rod – Bracket for torsion rod over center spring – Headlight mounting brackets – Grille to reinforcement hardware – Stool for tilt drive torsion rod)
G240803 Headlamp, Hideaway, 1968-69 GTO, Assembly, Left ( Rod assembly for tilt drive torsion – Reinforcement for headlight tilt door – Support for tilt drive torsion rod – Bracket for torsion rod over center spring – Headlight mounting brackets – Grille to reinforcement hardware – Stool for tilt drive torsion rod)
G241756 Hardware Kit, 1968-69 GTO, Hideaway Headlights, 96Pc
G241755 Vacuum Hose Kit, 1968-69 GTO, Hideaway Headlight
GTB0019 Return Spring, Hideaway Headlamp, 1968-69 GTO
G240593 Molding, Hideaway Headlamp, 1968-69 GTO, Headlamp Door, Right
G240593 Molding, Hideaway Headlamp, 1968-69 GTO, Headlamp Door, Left
GTB0018 Vacuum Canister, Hideaway Headlamp, 1968-69 GTO
97GTO48 Headlamp, Actuator Cover, Hideaway, 1968-69 GTO
GTB0021 Bushing, Hideaway Headlamp, 1968-69 GTO
G241637 Manifold Block, Hideaway Headlight, 68-69 GTO, Rubber
G240840 Knob, Headlamp, 1967-72 Pontiac & GTO
G241124 Tool, Headlight/Wiper Switch Nut, 1959-77 GM
KR00558 Switch, Hideaway Headlight, 1968-69 GTO
Also purchased a few manuals to help with the install.
VL12069 Fisher Body Manual, 1969
G240391 Assembly Manual, 1969 GTO/Grand Prix
G240426 Shop Manual, 1969 Pontiac
Js1969 is offline
post #2 of 7 (permalink) Old 06-21-2017, 04:41 PM
tooth's Avatar
I just picked up a 68 with the hideaways. Love the look, but they don't work on the car I have. I don't have the patience to mess with the vacuum, so I'm picking up an electric kit once I can justify it. It could be an easy fix, so maybe I'll give it a quick look before condemning the system.
Please keep this tread going with your progress. I might learn something in the process to figure out how to fix mine.
Js1969 likes this.
tooth is offline
post #3 of 7 (permalink) Old 06-21-2017, 05:30 PM
BLK69JUDGE's Avatar
Quoted: 74 Post(s)
hideaway
I see your in Washington .... Seattle Tacoma area ?
would you be interested in nice used hideaway parts ? some stuff you will have to buy newof course ... covers .... bushing kit ... and ....
Scott in Olympia
206 465 9165
BLK69JUDGE is online now
post #4 of 7 (permalink) Old 06-21-2017, 06:36 PM Thread Starter
Js1969's Avatar
Quoted: 5 Post(s)
Thanks but the list I have above is everything I've already ordered, I'm just looking for any parts that I might have missed. If I find that I am missing a part, I will check with you and see if you have the part before I order a new part.
By the way I'm in Issaquah, I'm still getting my footing up here in this state, haha
Js1969 is offline
post #5 of 7 (permalink) Old 06-21-2017, 10:53 PM
BLK69JUDGE's Avatar
Quoted: 74 Post(s)
I dont know if I ..
I dont know if I saw these on the list ... and I did read twice unlike my first post .. the hideaway mount brackets ...
theres always somethin .... like the brite light headlight bucket they dont warn you about thats different and hard to find
post #6 of 7 (permalink) Old 06-21-2017, 11:45 PM Thread Starter
Js1969's Avatar
Quoted: 5 Post(s)
Yes sir I got the headlight mount brackets.
But the buckets are something I have yet to find or understand. I wasn't sure if I could just use the ones that are used on the car now (non-hideaways) or If I need to find new buckets, which buckets I could use or needed to find.
Js1969 is offline
post #7 of 7 (permalink) Old 06-21-2017, 11:50 PM Thread Starter
Js1969's Avatar
Quoted: 5 Post(s)
If you have the buckets I would need then let me know your price.
Js1969 is offline
Converting back to 1969 GTO bumper 1965 LS2 GTO 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 9 06-26-2017 04:28 PM
converting a 71 lemans to a 70 GTO hack147 Gtoforum.com Site Help 4 01-19-2016 10:55 PM
Parts list for Hideaways? pontiacsniper 1964-1974 Tempest, Lemans & GTO General Discussion 5 06-06-2015 05:02 PM
Hideaways 68gtohawk8369 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 08-25-2010 09:15 AM
Change into hideaways. aseylys 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 04-05-2010 11:58 PM
